BX22D priority valve
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
Denver North Carolina
im not herer to argue with ya I had a qusetion I asked you didnt like the ansewer. The original question is this the releif valve and I got alot of ansewers but that one good day sir.
6,933
relief valve was probably open because fluid was dead heading with the steer lines being reversed that is a fact
The relief is open when you dead head the boom. Thats the foundational basis of the test.
Your loader valve was available as 3 or 4 position and with or without regenerative dump. What position did you test and was it a regenerative position?
6,933
I answerd question on post #20 I will not post any further when the help is part of the problem its not worth it any more thanks
The help you got in posts #6 and #8 would have saved you needlessly tearing the priority valve apart. It was helpful - you just ignored it.
What I am trying to politely tell you now is the chances you have 1300 PSI on bucket spool and 2000 PSI on boom spool is damn near zero. I also told you the relief is not causiing lower pressure on bucket spool and why.
Something is probably wrong with your bucket pressure test just like the flow test you did in #5.
