i just bought an older model BX1850 with a BX2750D snow blower. Blower operates up and down nicely but I cant seem to find the float mode. I’ve pushed the handle all the way forward and back with no results. Does the 1850 even have a float mode?
According to this it has a fourth float position:i just bought an older model BX1850 with a BX2750D snow blower. Blower operates up and down nicely but I cant seem to find the float mode. I’ve pushed the handle all the way forward and back with no results. Does the 1850 even have a float mode?
I assume you are using the loader valve to raise and lower the snowblower. If so you have a float position on the boom spool. Just like the loader it operates using two hoses.Thanks Dan. I see the link is for the FEL. I’m not sure it will work the same for the snow blower which only has two hydraulic lines.
Anything is possible. I’m new to tractoring so I'm not 100% what I'm even looking for. I’ve attached pics of my setup.I am wondering if your tractor has the wrong loader valve. I know when I ordered my BX22 that there were 2 different valves available. I have no idea when Kubota finally eliminated the "dual" valves. Your valve should have a model number on it, so if you post that valve identification number possibly someone here can figure it out for you.
Kubota usually puts a sticker on the tractor with the loader valve operations printed on it. See anything like this on your tractor?Anything is possible. I’m new to tractoring so I'm not 100% what I'm even looking for. I’ve attached pics of my setup.
If he is hooked to the bucket outlets it should be obvious from the left/right joystick action.Haven't used it yet this season, but my pretty sure my BX2750D blower on a BX2360 tractor uses the white/yellow pair.....those are boom, and red/blue are curl.
Will have to double-check.
Original post says up down function works fine followed immediately by statement that no fourth (float) position whem going front to back. OP seems to understand axis of boom operation and connections seem rigjt. So should he have float or is he totally confused?When I first seen this topic, I researched. I found nothing else relevant, the float function being an issue. That (to me) was somewhat a "huh?" response to the symptom, as to me, was the operator or whoever plumbed the hydraulics.
In the case of this model, up on the stick is down for FEL. This is where the stick reaches a detent. Push up past the detent, puts the FEL into the float position.
Down on the stick, is up on the FEL.
What am I missing?
Correct - my bad I neglected to ask what movement he needed to use. That will answer the question.If he is hooked to the bucket outlets it should be obvious from the left/right joystick action.
If I were the OP I would just answer the $1,000,000 question - what direction do you move the lever to raise and lower the blower.?Off note from my snowblower hydraulic connection picture, the blower came with red and blue “markers” but actually go on white/yellow pair.
There are corresponding markers on the tractor-side male connectors.
If I were the OP, I’d move the blue to white, and red to yellow.
In my mind, float should be there in the UP [fwd] position.Original post says up down function works fine followed immediately by statement that no fourth (float) position whem going front to back. OP seems to understand axis of boom operation and connections seem rigjt. So should he have float or is he totally confused?
But if he’s not using the boom (up/down) function of the loader valve, he won’t get float.In my mind, float should be there in the UP [fwd] position.
