BX1850 float
Bursey.ca
Bx1850, bx2750d, and 50” mower deck
Dec 27, 2023
Ontario
i just bought an older model BX1850 with a BX2750D snow blower. Blower operates up and down nicely but I cant seem to find the float mode. I’ve pushed the handle all the way forward and back with no results. Does the 1850 even have a float mode?
4,794
Bursey.ca
Dec 27, 2023
Ontario
Thanks Dan. I see the link is for the FEL. I’m not sure it will work the same for the snow blower which only has two hydraulic lines.
4,794
I assume you are using the loader valve to raise and lower the snowblower. If so you have a float position on the boom spool. Just like the loader it operates using two hoses.
5,143
I am wondering if your tractor has the wrong loader valve. I know when I ordered my BX22 that there were 2 different valves available. I have no idea when Kubota finally eliminated the "dual" valves. Your valve should have a model number on it, so if you post that valve identification number possibly someone here can figure it out for you.
Bursey.ca
Dec 27, 2023
Ontario
Anything is possible. I’m new to tractoring so I'm not 100% what I'm even looking for. I’ve attached pics of my setup.
4,540
Kind of weird the center two connections on the loader ports are a pair and the outer two are another pair but if that’s how it is, I guess that’s how it is.
To raise/lower do you move the joystick side to side, forward / backward, or some combination?
4,794
Kubota usually puts a sticker on the tractor with the loader valve operations printed on it. See anything like this on your tractor?
6,330
Haven't used it yet this season, but my pretty sure my BX2750D blower on a BX2360 tractor uses the white/yellow pair.....those are boom, and red/blue are curl.
Will have to double-check.
4,794
If he is hooked to the bucket outlets it should be obvious from the left/right joystick action.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
When I first seen this topic, I researched. I found nothing else relevant, the float function being an issue. That (to me) was somewhat a "huh?" response to the symptom, as to me, was the operator or whoever plumbed the hydraulics, was wrong or doing something wrong.
In the case of this model, up on the stick is down for FEL. This is where the stick reaches a detent. Push up past the detent, puts the FEL into the float position.
Down on the stick, is up on the FEL.
What am I missing?
4,794
When I first seen this topic, I researched. I found nothing else relevant, the float function being an issue. That (to me) was somewhat a "huh?" response to the symptom, as to me, was the operator or whoever plumbed the hydraulics.
What am I missing?
Original post says up down function works fine followed immediately by statement that no fourth (float) position whem going front to back. OP seems to understand axis of boom operation and connections seem rigjt. So should he have float or is he totally confused?
6,330
Correct - my bad I neglected to ask what movement he needed to use. That will answer the question.
This is mine and it does float.
6,330
Off note from my snowblower hydraulic connection picture, the blower came with red and blue “markers” but actually go on white/yellow pair.
There are corresponding markers on the tractor-side male connectors.
If I were the OP, I’d move the blue to white, and red to yellow.
4,794
If I were the OP I would just answer the $1,000,000 question - what direction do you move the lever to raise and lower the blower.?
Trimley
Jul 25, 2023
1,181
872
PNW-WA
In my mind, float should be there in the UP [fwd] position.
5,523
I'm curious about is WHAT are the two orange things are behind RCW's loader frame !!!
I'm pretty sure float should be felt as a 'clunk-clunk' when the joystick is pushed FULLY forward from neutral..
6,330
But if he’s not using the boom (up/down) function of the loader valve, he won’t get float.
Like Dan said, need to know how he’s moving the joystick. Just because mine looks similar, doesn’t mean my joystick is connected to the valve the same as his.
I don’t see loader mounts on the tractor, so it could be different if not tailored for loader function.
