bx1500 stalls when put into gear, $25 reward for solution
joesmith123
L295DT, BX1500
Mar 18, 2023
527
134
earth
That coupler is very easy to check, put the tractor in 2-wheel drive, range lever in either Hi or Low, and brake off. Jack up either of the rear tires leaving the other touching the ground and try to turn the tire in either direction by hand. If the coupler is missing the tire will spin without much effort. If the coupler is engaged, you will have to work pretty hard to turn it.
how would you like to get your prize, venmo cashapp paypal
joesmith123
L295DT, BX1500
Mar 18, 2023
527
134
earth
The machine is capable but slow
There is a moderate hydraulic leak from the front steering area, not gonna run it and keep adding hydraulic fluid
I'll take it apart tomorrow to see if its fixable, but I'm not seeing seals for K2511-16500 being available but maybe I havent looked hard enough
Been also making progess on the l295 project
edit: but so far I did level some land, move rocks around, the bucket is the best feature about it, moves amazingly, but wheels move slow
There is 0 difference between lo and hi gear that i am noticing
Its actually very fuel efficient, one gallon runs it for many hours
