BX mower deck failures
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
Has anybody else seen this problem? The side pulleys on the new BX 1860/2360/2660/25 midmount mowers come loose and destroy themselves. The four small bolts- size 13mm head- should be checked to be sure they are tight. I have seen a couple of these come loose and you end up having to replace the pulley. Not a big job, but def. a pain to someone who has less than 50 hours on there brand new tractor.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
We have seen this problem, not a lot of them mind you but enough that I started checking them on PDI. I haven't found any loose ones though!
Ed
eserv
May 27, 2009
2,140
139
Hardisty, Alberta
A little locktight wouldn't hurt but I think it's more a case of a few got through the factory without being properly tightened.
Ed
3,298
Well theres blue lock tite on them now!!! I pulled the mower off to sharpen the blades, and after i read this , i though i would just for shyts and giggles I would check them 3 out of 8 were loose, not falling off loose mine you but loose enough that the bolts turned with out a lot of trouble,, gona be a long time before they trun by then selves again,,, Thanks much for the heads up:D
Will In Tx
L3400 HST/FEL, Box Blade, RTV 900 Camo, ZD323 Zreo Turn Pro Mower + More
Mar 21, 2010
303
Rosharon, TX. USA
I have found my Kubota L3400 bolts loose in different places.
So now I check EVERY new piece of equipment that rolls on to the property. :cool:
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
Cking for loose bolts on everything you can get a wrench on should be at the minemum a once a year thing. A fighter plane in the Air Force is every single time it flies!!!
Orange in WI
L3130 with loader-BX2360 with Loader,front mount snowblower,60MMM
Jun 16, 2010
10
Fond du Lac,WI USA
My decks coming off for a gear box oil change next week. Thanks for the heads up,I'll check that as well.
3,298
A good question about gear box oil, I use Redline Super Shock in the Harley tranny would that work in the mower gear box too?
bkusich
mowing, hauling, snow removal
Jun 24, 2010
Freedom, PA
I had this same problem; so how difficult is it to change the pulley? The vibration from the loose bolts causes the holes in the pulley to get too big.
3,298
ipz,,,,now I have to clean my screen,,, I don;t know why that struck me so funny:D
denap
BX25, MMM, Bagger, Wallenstein Chipper
Jul 3, 2011
Bourne, MA, USA
Anyone know the difficulty in replacing these pulleys? I have the same problem on a 60" MMM. Also, does anyone know the part # and $?
thanks
