BX guys
3,623
Well I couldnt figure out what was making a rattling sound on the front end of the BX I opened the hood and the grill and side panels kind of just sat there no hooked to anything. Hummmm ???? The ears that the thumb screws go through to hold it in place are gonzo, so aint nuttin holding it in pace other than the hood which I think is the only thing that kept it from falling off... So I ask, and I an sure others have had the same issue with the plastic front end. What did you do to fix it, I called the stealer,, and as soon as my nuts come back down I might think about buying one, till them it is open motor,, any body ????
armylifer
Mar 26, 2013
2,060
786
Thurston County, WA
I had the same problem with the 'ears' breaking so I just removed the plastic cowling altogether. I have been running it that way for several years now.
5,871
Skeets- had a few buddies here same happen on their BX. Mine’s okay so far as of yesterday.
Couple pulled the cowling off like @armylifer. Couple just let it rattle around in there with broken tabs.
One or more talked about trying to fix with epoxy because they had the broken pieces. Don’t recall anything about the success of the fix.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,444
1,874
Western MT
I don't know if it's similar, but my mower engine cover lifts up. Over time, it lost the the little vibration dampeners. So, I put weatherstripping between the metal and plastic. It's worked fine for a few years.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
161
209
NC
There was enough plastic of the cowl left on my old one that I used 1.5" wide fender washers under the thumb screw. It reached enough of the plastic cowl to hold it down. I've since replaced the whole cowl with a shiny new one.
SMRY
BX24
Sep 8, 2024
127
91
VT
I too have the plastic hood arrangement. Here's several shots of a fix for the moment, as I'd like to keep intact helping to keep heavy snows out. Others may wish to visit the hardware store pickup a small roll of metal strapping. The holes are correct size for the knobs to pass through. Myself you can see lost a knob at some point, using a bolt for now with correct thread to fit the factory welded nut on the underside. At the sides I just used self-tapping sheetmetal screws with hex heads passed through the straps there as well. The other shot of top of hood just about where the locking mech / latch point is the metal frame that passes along the length of the hood (from latch to headlight areas) the plastic also broke holding the metal at the latch end. I drilled a hole thru that metal along with the plastic & bolted the two together. The plastic has already begun to spider been several yrs. since that was first repaired. Anyways, if you've run into that issue as well. May wish to give that a try too. Eventually I'll probably add a thin plate covering the spidering and self-tap the plate / hood as one. Surely a nice sheetmetal hood would have been a better design along with a metal fender arrangement. Anyways, hopefully may provide some repair ideas / inspirations fitting your own needs.
5,871
If my memory serves, I added a flat washer to each side. Don’t recall if the threaded knobs are OEM or my addition. Was probably 10 years ago.
Like someone said, if the tab(s) are broken a fender washer might do the trick.
SMRY
BX24
Sep 8, 2024
127
91
VT
Your tabs look to be in fine shape. The knobs themselves are factory as well. If you look at mine (photo) in comparison the plastic tabs are no more.
SMRY
BX24
Sep 8, 2024
127
91
VT
Well, being such a nice day (warm 70s), &, talk of BX & repairs, caused me to go back out, cut me a couple pc's of tin from old roofing leftovers, no real measurement to speak of. Shaped & cut the 1 pc on the underside around the metal work for the hood latch / stiffener, while the exterior just a square. Nothing fancy, should get the job done nicely, perhaps, preventing excessive flexing, causing the plastic to crack / spiderweb further.
SMRY
BX24
Sep 8, 2024
127
91
VT
I had looked into a new hood & side panels from several Northeast "stealers". I want to say last spring. Also looked into new plastic fenders as they're cracked everywhere. I recall at the time they quoted me $2300 for the hood & side panels, while the rear fenders $2500. I haven't given up the notion of new plastic, though, not in any rush at those prices.
SMRY
BX24
Sep 8, 2024
127
91
VT
Sadly, baby "OJ" suffers even more this winter. Due to minus temps for so, so long, have really taken further hold on poor baby "OJ", as, the plastic body parts have further cracked to no end, even chunks falling out, just about with each use. Eventually, be just framework & a seat, perhaps, by spring if there ever is one. However, on a good note. The $9 heated seat cover been working flawlessly, also, the $19 fabric tractor cover, fits much better than the $79 hvy duty that didn't last perhaps a half yrs time.
Sidekick
Jul 29, 2023
699
707
N.Y,
I keep losing the thumbscrews off my BX mower deck plastic shields. They were 8 bucks a shot from Kubota so bought 10 from Amazon a couple years ago for 6 bucks.
5,379
FWIW....
seeing the picture in #9 post, I suggest larger 'fender washers' under the knobs. Big enough to almost cover the 'tab' on the right and add a lock washer too.
The greater the washer surface the better support.
