BX-25 Coolent fan rubbing shroud
snowman1
BX25-Post hole digger-back blade
May 27, 2013
23
windfield pa
I took notice today, that some time my fan blade must have came in contact with the shroud . ends of blades are rubbed ,and part of the shroud is missing.Any ideas what happend.
2,609
Something get in there that should not have? Stick? Rock?
Pull belt off of fan, any unusual play in the fan movement?
The shroud could have moved too, where on the shroud did the blades make contact? Top? left or right? or bottom?
Could the radiator have shifted to the point where the shroud was pushed into the blades? Looking at mine - this would be tough to do!
Could the water pump be at fault ? Looking at the engine - the engine can move slightly on it's mounts, but it would have to move a great deal to hit the shroud.
Pictures are worth those 1,000 words!:) Here is my BX-25D.....there is about 3/8 of an inch between the shroud and fan tip. (sorry -little fuzzy on pic)
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Yeah what he said.
nzzshl
1982 Yanmar GT14(YM146), 2015 BX25, BX5450 snowblower
Jan 12, 2015
85
Fenton, Mi
I'm thinking motor mount fastening issue myself. Looked at my BX25D and see no immediate reason that is likely to happen. If something other than a mount issue is found, please share it........my tractor is maybe too young yet to have developed the problem yours has. Thanks, Chuck
