Bucket teeth
xrdan
l3600
Jul 10, 2018
mineral bluff ga
Putting this out there for the community- not affiliated with this company etc, etc.
I was leveling a spot for a pole barn and one side had to go down about 5 feet. I have a l3600 with a la680 loader, 3way roll over scrape on the back that weighs over 700lbs. It went ok at first, then I was going over it with the scraper teeth, then I piled about 500lbs of rocks on the scraper. With about 18" to go the dirt was a crumbly rock/clay mix and 1200lbs bearing down on the scarifiers just bounced along the surface. For my bday my kid got me a cutting edge called a Piranha. You have to drill 2 holes in the bucket to mount it, but if you saw my bucket you would know that wasn't a concern.
Anyway, to make a long story short- I was now able to easily tear through the last foot and a half of dirt and finish the job. I was about to have to rent/pay someone with a bigger machine to finish it for me. Would highly recommend if you needed something like this.
re54drider
L2800, FEL, Bush Hog
May 9, 2011
80
36
Goldston, nc
Glad to hear someone besides me has benefited from a tooth bar. I put one on my 6' SSQA grain bucket and am amazed with its usefulness every time I use the FEL. It is great for getting rid of privet and other unwanted stuff and it increases the earth moving capabilities by a bunch. With practice I am learning to take full advantage of the teeth. Just make sure the teeth are on the ground when you park it.
bbxlr8
Mar 29, 2021
455
314
Eastern PA
Put one on mine soon after I purchased it in 21 and never looked back. Very happy with it
BTW, the edge will tear you up initially. I have a variety of percentages of rock soil mix, so I never bothered to resharpen.
Be aware of the limitations of the equipment though. It helps me to get a good fill on previously loosened material here, but it is NOT a bulldozer! ;)
Bee-Positive
Nov 16, 2022
993
945
Amsterdam, NY
BXpanded Piranha Bar was priceless for removing sod, digging the footer, backfilling, spreading stone in my clay soil building a retaining wall. Couldn't have done it without some sort of toothed bar.
Shawn T. W
Dec 9, 2024
782
1,411
SW Missouri Ozarks
Mines been used quite a bit, put it on about 4 years ago, and 750 hours ago ... Go get yours dirty and scratched up! šŸ˜‚
Trust me though, the "paint" they use is seriously heavy duty, it will take quite awhile ... I have quite rocky soil!
netspyder
L3010HST
Jun 9, 2025
36
72
Missouri
love my bexpanded piranha! levelled land, dug out stumps, pushed over trees... i'd say the value rivals the chipper!
wma01541
Kubota L5470, Ford 545D
Jan 4, 2022
Worcester County, MA
I added ATI and Titan toothbars to L5740 and JD3032 buckets ; both were add-ons that go over the cutting edge. Teeth are great, durable and the points are replaceable. If you need a flat edge for winter snow/ice work, just unbolt the toothbar before winter. Good for digging dirt, rock, lossening up gravel piles, regrind asphalt, busting up snow/ice pile-ups due to plowing, etc https://palletforks.com/products/23tf-bucket-tooth-bar ; can't find url for the ATI set unles they don't make them anymore; other options/brands https://www.everythingattachments.com/Tractor-Loader-Bucket-Bolt-on-Tooth-Bar-s/8926.htm
