Bucket teeth
xrdan
l3600
Jul 10, 2018
mineral bluff ga
Putting this out there for the community- not affiliated with this company etc, etc.
I was leveling a spot for a pole barn and one side had to go down about 5 feet. I have a l3600 with a la680 loader, 3way roll over scrape on the back that weighs over 700lbs. It went ok at first, then I was going over it with the scraper teeth, then I piled about 500lbs of rocks on the scraper. With about 18" to go the dirt was a crumbly rock/clay mix and 1200lbs bearing down on the scarifiers just bounced along the surface. For my bday my kid got me a cutting edge called a Piranha. You have to drill 2 holes in the bucket to mount it, but if you saw my bucket you would know that wasn't a concern.
Anyway, to make a long story short- I was now able to easily tear through the last foot and a half of dirt and finish the job. I was about to have to rent/pay someone with a bigger machine to finish it for me. Would highly recommend if you needed something like this.
re54drider
L2800, FEL, Bush Hog
May 9, 2011
75
34
Goldston, nc
Glad to hear someone besides me has benefited from a tooth bar. I put one on my 6' SSQA grain bucket and am amazed with its usefulness every time I use the FEL. It is great for getting rid of privet and other unwanted stuff and it increases the earth moving capabilities by a bunch. With practice I am learning to take full advantage of the teeth. Just make sure the teeth are on the ground when you park it.
