My 48 inch king kutter brush mower needs blades. At least one of the bolts has the spline stripped. There appears to be a shoulder on the bolt so I can't just cut the head off. I'm thinking I need a giant pipe wrench . Is there a better idea?
Does your mower use some kind of stud for mounting blades? When you say bolt spline I'm picturing wheel studs.My 48 inch king kutter brush mower needs blades. At least one of the bolts has the spline stripped. There appears to be a shoulder on the bolt so I can't just cut the head off. I'm thinking I need a giant pipe wrench . Is there a better idea?
If it's (like) the #15bolts/nuts set in drawings below maybe have to order another set and cut them off? Can you remove the stump jumper and torch cut off the frozen bolts? Sounds like some kind of more extreme measures are in order anyway.To be clear I was trying to get the nut that holds the blade to the stump jumper. I have a 40 inch breaker bar in 3/4 drive. Doesn't seem to be enough.
That would be my preference but the bolt has a shoulder on it. Cut the head off and the shoulder still holds it (I think) Can't get the angle grinder into the counter boreI would probably grind the head off of the bolt with an angle grinder. Much more delicate than a torch.
Then drive the bolt toward the nut.
If you can get the mower on it’s side and tied to something secure that would make the work much easier to do.
I thought that's where the term ""cheater pipe"" originated by procuring/utilizing a long piece pipe on breaker bar handle. If you resort to cutting off nut then just drive remnants of bolt out of blade holder frame.To be clear I was trying to get the nut that holds the blade to the stump jumper. I have a 40 inch breaker bar in 3/4 drive. Doesn't seem to be enough.
If the spline was holding that plus a little heat might be the ticket. Don't think that a pipe wrench will hold that much torque though. I don't have a torch to cut the nuts off through the access hole. Think I could get in there with an angle grinder if I got the stump jumper off?I thought that's where the term ""cheater pipe"" originated by procuring/utilizing a long piece pipe on breaker bar handle. If you resort to cutting off nut then just drive remnants of bolt out of blade holder frame.
Back in May I made a comment above in this thread that “blade changing can take on a life of it's own!”. Looks like my comment was spot on, I’ve been down that exact road…..lolSo I figure I'm overdue for an update just in case anyone is interested. I ended up cutting flats in the round heads of the bolts so that a wrench would hold them. My pancake compressor is labeled at 1 hp but is probably more like 1/2hp running, but you can get about a 10-15 second burst out of the Impact wrench with it. One of the blade bolt nuts fought me all the way, so it was a quarter turn, let the compressor catch up, lather rinse, repeat. The other one just needed to be loosened and it came right off.
I ended up replacing the blade pan as well. I welded and ground something that would have held for installation, but not sure about the long term, so I ordered a generic one from agri-supply along with a new castle nut for it. The output shaft nut fought me all the way as well, but I was able to keep the PTO shaft from spinning and take it off with a breaker bar once it was loosened with the impact.
Could not get the old blade pan off. Found out one of my neighbors has a oxy-acetylene torch We cut it smooth in half and it still needed to be pounded off. The heat from the torch must have been the last straw for the seal, because it started to leak, so I ordered a gasket and seal.
Replacing the seal went like one would expect it to go. The blade pan went on easy as well. The only issue that I had with the blades is that I had to hog out the access hole for the blade nuts. It wasn't aligned when I got it, but it was close enough that I could get a socket on and off with the old blade pan. The new one must either have the holes slightly closer to center or be a little more shallow. I could get the socket on with the nut backed off, but once it was tight, it wouldn't come off. I guess I probably should have put the blades on before I put the pan on and it wouldn't have been a huge deal to pull it back off and change the assembly order, but I figured that I'd probably want to be able to pull the blades off in the future, so i opened up the hole.
You weren't wrong.Back in May I made a comment above in this thread that “blade changing can take on a life of it's own!”. Looks like my comment was spot on, I’ve been down that exact road…..lol
Hopefully you are now ready for years of quality use from your rotary cutter, make sure you have the correct shear pin fitted or slip clutch adjusted correctly.
