Broad cast or drop bottom
3,989
Now I need a bit of info here guys and gals. I got the soil test back again from Penn State Ag, this time times were right. Anyways as it turns out they still say I need 9000 pounds of lime per acre, ( 22.5 tons)yeah I know thats a bunch for 5 acres. I want to plant something with next year. As you know lime aint cheap and I really dont want to waste any more than I have to, I figure disk then lime and then again in the fall and then spring. Hence the question a drop bottom or a broadcast type spreader. Anyway ya look at it its not going to be cheap or fun, and I contacted the local farm supply dealer and he said that he couldnt get to it till late summer with his spreader truck. Anyways kids, what say you?
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I don't have an answer for you, but I do know lime is very heavy and not all spreaders can handle that.
Sent from my LGMP260 using Tapatalk
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
My advice is pelletized use broadcast spreader, powdered use drop.
BigG
Sep 14, 2018
1,951
773
West Central,FL
Does the county extension service have a spreader to use? I would call the other ag supply dealers. I can not believe he is that busy. It should not take but a couple of hours out of his day to spread a truck load of lime.
2,915
1,028
I would find a fertilizer plant that does custom spreading with a truck and have them come in and spread it for you. That’s a lot to spread otherwise. The ones around here do that. The charge to spread is not too bad when you are buying the lime from them.
SidecarFlip
Banned
557
I use pelletized in my ptp spreader. Ag lime has to be spread with the right equipment because it's fine and cakes up.
Magicman
Oct 8, 2019
5,856
8,783
Brookhaven, MS
knotholesawmill.com
Is pelletized the same ratio? 9,000 X 5 pounds of pellitized would be very expensive.
It does need to be applied as quickly as possible because, as you know, lime takes a while to break down and do any good.
3,989
Thats why I want to do, 3, 6 month applications,, well at lest thats what I want to do,,lol
