Both front wheels are locked up
Will.05
Kubota b7500
Jun 22, 2026
Was mowing a pasture and thought I hit something looked underneath nothing was hit and now both front wheels won’t turn even if I pull it with a side by side front wheels just drag. Did I blow the front dif
b7500
3,499
I had a B7100 gear hub failure that sounded similar except it only locked up one side:
If it is both sides I would suspect a diff problem. :confused:
10,803
Have you shifted it out of 4wd?
Lift the front end off the ground and try to spin each tire.
10,803
With it in 2wd lift only one tire off the ground and see what it does.
