Both front wheels are locked up
Will.05
Kubota b7500
Jun 22, 2026
Was mowing a pasture and thought I hit something looked underneath nothing was hit and now both front wheels won’t turn even if I pull it with a side by side front wheels just drag. Did I blow the front dif
b7500
3,577
I had a B7100 gear hub failure that sounded similar except it only locked up one side:
If it is both sides I would suspect a diff problem. :confused:
11,129
Have you shifted it out of 4wd?
Lift the front end off the ground and try to spin each tire.
11,129
With it in 2wd lift only one tire off the ground and see what it does.
11,129
Diff, ring and pinion (or bearing), or something in transmission is locked up.
Pull the propeller shaft and try the same test.
