What a stupid design. I took the two dome washers put them on first, then the blade then the spigetted washer then the nut. Tightened, then stitch welded the spigetted washer to the blade. For new blades cut the washer off with an angle grinder with cutting disk. Now when I hit a tree root the belts slip a bit and stall the engine.
