bad ground
Pwm613pwm603
B7610HST, backhoe, loader, 64" trailing mower
Mar 1, 2016
North Fort Myers, FL
Based on someone's help here, my 7610 has a bad ground to fuel gauge. I have tried to ground direct to frame but that does not work. What can I do?
10,773
If your grounding it to the frame and it's not working then you have a different problem, either a bad sending unit or a bad gauge or no + power going to the gauge. ;)
9,117
If your grounding the end of the wire that attaches to the sending unit directly to frame and only getting it to read 1/8, then there is an issue in the wire. Most likely a loose or bad connection in either a quick connect or one of the terminals.
