Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
I had noticed the front left wheel running a little out of true and yesterday heard a "squeak" that I thought might be a bearing noise.
I raised the front left and confirmed the wheel was running out by about 10 mm but when I spun it by hand the squeaky noise seemed to be coming more from the front drive shaft area - maybe a front uni joint ? I'll get back to that.
After removing the wheel I found that the hub was running out by about 4-5 mm. Looks like a section of the flange might have taken a hit before I had it. Maybe related to the missing wheel stud where a different bolt had been fitted from behind ? Need to remove it to confirm its just the flange and to try to press it straight.
I need some help. Does the housing that holds the hub and final drive stub come off with the 6 bolts removed or is there more ?
I have a copy of the 137 page WSM but can't find any reference to this or any pics.
youtube.com
28 January 2026
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
