After reading through the HST's Operator Manual, couldn't figure out if the tractor's hydraulic system (attached to the engine block) runs on the engine's oil or has its own closed oil system. Anyone know if the engine hydraulic pump uses the engine oil or its own oil?
If it is a closed system and uses its own oil, what kind of fluid/oil does it use? Figure it needs changing.
Thanks!
Thanks!
