B7100 blow by?
newshb_k
41
Jordan
Hi guys
I have got B7100 recently, and going through all around servicing
I checked the engine, and noticed some gases when I remove the cap, as in this video
Video
is that blow by, and how bad is it. Do I need to go through engine overhaul?
Thanks
2,617
That close up shot is hard to see "all the blow by" ....... but I get the big picture.
Is IT hard to start AFTER you glow for 10 seconds or more?
Has it been run hard in a while? A diesel like that, that has not been used in a bit will have that - run it, and run it well.
IF it starts "well" using the glow plugs - and my 3 will NOT start if they are not glowed a bit.
THEN leave it alone ......... aint nothing wrong with it. AND when you do pull a load on it - it may blow some particulates out of the breather tube - again, somewhat normal.
If it starts and runs .......... allow it to do so!
newshb_k
41
Jordan
Thanks
Yes it runs normally fine with the glow plugs, and yes it has a hard start recently; as it was parked for months before I bought it recently, and the diesel is old for sure.
I will run it and enjoy it 😊
2,617
Thanks
Believe me when I say ........... the more you run it "hard" the better it will get, to a point that is.
Remember - a hard working diesel will run longer than a diesel that has been run at idle and babied.
How many hours on this machine btw?
newshb_k
41
Jordan
Thx
not sure about the hours, since it doesn’t have an hour meter. It was imported from USA to Jordan (Middle east).
I am planning to add hour meter, thermometer
2,617
Thx
HST or Geared?
4 bolt front rim or 6?
Pictures ?
2,617
Oldie but a great machine! Late 1970's or early 80's model.
you can get WSM and operators manual here too:
