ThanksThat close up shot is hard to see "all the blow by" ....... but I get the big picture.
Is IT hard to start AFTER you glow for 10 seconds or more?
Has it been run hard in a while? A diesel like that, that has not been used in a bit will have that - run it, and run it well.
IF it starts "well" using the glow plugs - and my 3 will NOT start if they are not glowed a bit.
THEN leave it alone ......... aint nothing wrong with it. AND when you do pull a load on it - it may blow some particulates out of the breather tube - again, somewhat normal.
If it starts and runs .......... allow it to do so!
Believe me when I say ........... the more you run it "hard" the better it will get, to a point that is.Thanks
Yes it runs normally fine with the glow plugs, and yes it has a hard start recently; as it was parked for months before I bought it recently, and the diesel is old for sure.
I will run it and enjoy it![]()
ThxBelieve me when I say ........... the more you run it "hard" the better it will get, to a point that is.
Remember - a hard working diesel will run longer than a diesel that has been run at idle and babied.
How many hours on this machine btw?
HST or Geared?Thx
not sure about the hours, since it doesn’t have an hour meter. It was imported from USA to Jordan (Middle east).
I am planning to add hour meter, thermometer
It is GearedHST or Geared?
4 bolt front rim or 6?
Pictures ?
