B6100 ignition switch
drbenway
B6100
May 9, 2012
12
New York
Greetings! :)
Thanks for all the great info here [and the youtube videos, Vic]
I have searched but cant find anything like this. The tractor is new to me.
I've checked the wiring on the switch with the wiring diagram, and it seems to be correct.
However, when the key is turned to the left [to heat the plugs] the starter cranks [if the clutch is depressed] :eek:
the starter also cranks when turned to the start position [far right] as it should
tractor starts and runs well
PO lost the key and was using the butt of a house key to turn the switch. [I've ordered a new key]
any advice/comments much appreciated
thanks!
3,530
PO lost the key ,,,,,,,,, Would that be your Parole Officer??? :D
Kytim
B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Aug 14, 2009
848
12
Western Ky
Morning and welcome! Now to the problem, I had a similar problem when the Previous Owner of my B7100 was using whatever he could jam in the slot of the switch. It needed replacing. Which is what I had done when when I had it in the shop for a clutch R&R. Solved all the ills, clutch too!! Haha
drbenway
B6100
May 9, 2012
12
New York
thanks for the replies
well, I sprayed it with teflon/silicon and then contact cleaner, moved the key back/forth through the positions with the new key and now it seems to work fine....
famous last words :D
