B6001 - LED Lights
Holleyman
Kubota B6001, Caterpillar 252B, AM General M813A1, Ford 8N, Komatsu PC30
Sep 25, 2013
70
80 acres in Athabasca AB
Well I tried working several times with stock lights during the later evening, it isn't fun.
I ordered some 4" round LEDs for $25.00 for a pair off of Amazon. I looked for installs on the forums but I didn't want to modify the hood or have exposed hardware.
Here's what I came up with
I only had to bend one tab on each side to mount to the LED light. I then use 3/4 utility strapping and a long screw left over for a TV wall mount kit that was exactly the right length and size. Threw in a 2 pin Deutz connector and clamp.
Now I have a set of lights that I will donate to a B series rebuild somewhere.
JPB7745
L2501, B8200 and Ford 3000
Aug 27, 2018
52
Okatie, SC
Nice job on the install modification, hopefully those new LED's will shine the way for you into the night!!
mickeyd
Mar 21, 2014
1,192
Guin, AL
Great job. Very professional looking. ;)
5,246
1,031
Many older B series Kubota's used alternating current for lighting. A few others found that their new LED's would not work. I have not studied the wiring diagram for your tractor.
Kubota did this to get the maximum efficiency from a small dynamo as rectifying the dynamo output to direct current effectively threw away have the output. They only rectified enough to charge the battery.
If you have a multimeter, measure the output voltage of the existing lighting circuit.
If indeed you have AC, then we can think about a work arouund. Don't leave your new lights on if they are not working perfectly.... perhaps pulsing if on at all.
