B3200 Fuel stop lever
fisherman457
Kubota B3200
Jun 22, 2026
Pennsylvania
I have a 2010 b3200 that I am going to check the compression test on with a glow plug adapter and need to cut off the fuel so that it doesn't inject during the test. The workshop manual states "after making sure that the stop lever is set at the stop position (non-injection), run the engine with the starter and measure the compression.". I cannot find a diagram with the stop lever in the workshop manual or owners manual, but there is a lever below the throttle lever. Is this the correct lever and/or is there a better method to stop the injection?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,800
2,363
WestTn/NoMs
You're in luck. On your machine, just pull the electrical connector off the fuel solenoid. You have a no power- no run version. After you pull the connector, try to start it to confirm.
whitetiger
Nov 20, 2011
3,637
2,060
Kansas City, KS
Yes, that is the shut-off lever. I use a light-duty bungee strap and pull it to the off position. It is spring-loaded to the default ON position.
