B2650cab with Landpride RGR1258
Duke
2018 Kubota B2650 HDSC with FEL and 72â€￾ rear blade.
Jul 29, 2014
31
Metamora, MI
I have 3" spacers on my B2650 with turf tires which should put it at 60" wide. With the 58" wide tiller I will be 2" wider than the tiller's cutting path.
My question is will being 1" wider on each side really make a difference?
My thought is if it is than I could offset the 3 point to one side a couple inches if I have to but I would rather not.
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
316
284
catlettsburg, ky
You can loosen the u-bolts, that hold the lower link mounts, on your tiller. Then slide the mounts left or right to offset your tiller.
Freeheeler
b2650 tlb
Aug 16, 2018
706
525
Knoxville, TN
As far as I know mine is stock, so I don't know if there are any spacers or not. When I measured, I went from the outermost sidewall point and it was just a fraction under 60". The actual footprint width of the tread (contact with the ground) is more like just under 56". I don't think you'll be leaving tread marks with the 58" tiller, certainly not enough to make offsetting to one side a benefit. I'll actually measure the tread width tonight for curiosity.
Duke
Jul 29, 2014
31
Metamora, MI
Well I measured across the outside edges of the tread and not the sidewalls and came up with 58” right on the money. So if I can drive really really straight and NO BEER then the RGR1258 should be fine.
