B2602 or Massey 1526
tecknomage
MF B2600 BCS 743 ROXOR
Jul 15, 2021
tennessee
Looking @ these 2 machines, any suggestions? One thing, I cant find any reference to a backhoe (even from dealer) on the 1526. Looked @ Kioti CK2510, but it still only has 2 range gear box, & lack of real dealers (long term ones, anyway) near me
David
hedgerow
377
350
Malcolm NE
I can't speak on the size of tractor's you are looking out but I looked at the Kioti's and the dealer seemed good the tractor just concerned me. I looked at Massey since I was replacing a AGCO ST-25 that I had good luck with and the same company builds the Massey's today. Not a lot of dealers around and or tractors to look at. I ended up buying Kubota and did up size more than I had planned and bought a MX 6000 HST with FEL and so far love the tractor.
D
Deleted member 47704
Guest
Dealer nearby was the deciding factor for me.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,467
490
Can't go wrong either one. Both very good, well built, reliable machines. I don't think the 1526 has a factory backhoe option? But there may be a Woods one for it? MF has an implement deal with Woods.
I love how the Massey's hydro pedals control engine RPM. But I wasn't crazy for the loader joystick mounted on the loader stanchion. And the ROPS bar is huge and bent forward. And it doesn't have steering brakes, only a single brake pedal.
For me the choice between those two would come down to dealer, but the Kubota is a bit more "deluxe" with more available options.
PaulL
2,570
1,537
NZ
My sister in law has a Massey, I didn't like it as compared to the Kubota, it didn't feel as nice to drive. I think I recall that the smaller Massey tractors are contract manufactured for them - so check what brand they are underneath. It might be an Iseki?
Neil from Messicks (by no means an unbiased source) has things to say about badge engineered tractors - neither the brand (Massey) nor the manufacturer (Iseki?) have much incentive to keep good inventory of spares. If it's literally just an Iseki with a Massey label on it, that's actually better because Iseki will keep the parts for their own machines. But if it's an Iseki with a bunch of differences, then those different parts may become hard to source over time. Neil makes a point of the parts availability for quite old Kubota tractors - Kubota has a strong incentive to keep those parts around.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,467
490
Iseki has been making Massey's scut's and cut's for a long time. No problem with parts. Massey (Agco) is as good at supporting their stuff as the other big players.
Me, I love my Kubota products, but Massey is good too. Go try them out and see what you are comfortable on, then pick the dealer that will treat you best.
BigG
Sep 14, 2018
1,951
773
West Central,FL
I had a MF 1528. It was a good tractor until it got about 1700 hours on it. Then I had some major issues.
#1 was the front axle broke off of the frame. The front axle was mounted onto a 1.5 inch strap that ran from one side of the frame to the other. It broke the weld when I was mowing a pasture field and dropped into a bull hole.
#2 the shaft that supplied the power to the PTO broke inside the transmission.
#3 as I was box blading to gather up the materials that where being dragged out of a pond the rear axle housing broke.
FYI
