Billdog350
I have a good friend who was stung by the tractor bug. After a (used) green story that went horribly wrong, he is about to buy Orange (new) machine.
In the B series there are the B50 series which have DPF and the 01 (B2301 and B2601) which do not. Apparently the salesman told him that the B2601 is actually just the detuned version of the old B2910 motor....rock solid and no computer or DPF garbage to cause issues.
Anyone hear the same?
Here are the specs I've found:
B2910
http://www.kubotaengine.com/products/engines/vertical-diesel/kubota-05-series/v1505-e4b
http://www.kubotaengine.com/products/engines/vertical-diesel/kubota-05-series/d1105-e4b
The bore and stroke is the same on both, 78mm..however displacement is different on the higher hp machine...so it must be cam timing? I thought bore and stroke determined your displacement....
B2910
