B2601 counterweight
Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
Jun 30, 2017
240
Northern Canada
My sister has asked me to build a counterweight for her husbands B2601 for a surprise gift that she wants to give him. What would be a good weight for this tractor. I built a 600 lbs one for my L2501 but im wondering if I need to go that heavy for the smaller tractor. I built mine out of concrete but I am thinking of building his out of steel just for ease of adding options like shovel holders and a receiver hitch kind of stuff. That way he can fill it with sand or rocks or whatever he wants for the weight.
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
i had 500lb for counterweight with loaded tires on my 2601... never hurt it or took anything away from it at all.
there were still times that i had enough on the forks in the front that it was light in the back.
the L2501 is a little heavier tractor, but the b2601 actually has a stronger hydro system with more lift capacity..... & pretty much the same engine power.
old and tired
1,919
1,297
My thinking is that your ballast would fit the B2601 better and you need closer to 800 pounds... just my guess. I have ~800 pounds for my l2800.
Chad D.
255
131
Eugene
For comparison, I keep a LP grader scraper hanging off the rear when I’m doing any front lifting work. Whether it’s with the bucket or grapple.
My grader weighs 511#, per LP website, and I have a third cutting edge on the back side. Figure 550# plus dirt and Quick hitch? Point is, a lot of that ~600# is quite a ways behind the 3-pt, so it would be the equivalent of more weight in a weight box that is tighter to the rear end.
With a heaping 60” scoop of quarry rock (~2,700# per yard), I wouldn’t want any less counter weight. The rear tires always stay down, but you certainly know their is less weight on them... my tractor is a B2650 with loaded R4s. A little heavier than the 2601, but not much.
My suggestion would be to build a box that can be added to for tool holders, and carry enough sand weight to max out the 3-pt capacity. If your BIL doesn’t need it full, he can always run it 1/2 or 3/4 full. Top it off if he ever needs max weight out back!
