B219 owners, favor needed
2,863
Could someone with a B219 FEL do me a favor & measure the outside diameter of the hydraulic cylinders? I meant to do this myself & it slipped my marginally functional mind until I was about 75 miles from the tractor. DOH! My guess is about 2.375, but I need a more solid figure to research a new project for improving said FEL.
Thanks in advance.
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
Is the B219 the one with the front PTO pump? If it is, I have one and can get you the measurements.
2,863
Yup, that's the one.
Just for clarity, 2.350" includes paint? If so that's what I'm interested in. I think mine have been repainted, so they may be a little larger, but if someone else will chime in for kind of an average, I'll be good to go.
Thanks!
BadDog
Jun 5, 2013
579
Phoenix, AZ
Well, it includes paint such that it is. Most of it is pretty well burnt, but it's there. If you need more precise, I can put a micrometer on it (or even a good caliper) instead of the worn vernier caliper I grabbed (which I generally use around the shop for rough measurements).
2,863
I'd appreciate a more accurate measurement if it's not too much trouble- it's one of my curses- 30+ years as a Toolmaker & Research Technician.
Tooljunkie
May 13, 2014
4,150
Lil foot is definetly not a T.L.A.R. Graduate. If i dont have to, i wont measure....that looks about right.
Good luck with the project.
For drying fire hose. Its built into a room,so onsite repair is necessary.
2,863
LMAO- you're right there. Borderline OCD on some things.:rolleyes::D
2,863
Another measurement needed- Could someone please confirm the ram diameter? Should be 1.125", but I'd like a confirmation before cutting material.
Thanks in advance.
BadDog
Jun 5, 2013
579
Phoenix, AZ
Ok, I drug out the micrometers just for you. The measurements were so surprising, I went back and checked calibration to be sure, and they were both accurate within tenths. Anyway, the tube on the cleanest closest to virgin place I could find checked at ~2.376(+) without paint (looks like my verniers are in worse shape than I realized). Shaft is at ~1.126. Both varied by a few tenths in different areas, particularly the tube (which varied by a couple thou +), but that's what I got. And that's setting in the sun with micrometers coming out of a cool dry room. Sorry, no environmental control room to normalize my tractor in for 48 hours, but best I can tell that material is imperial sized.
2,863
Excellent! Thanks BadDog! I now have all the dimensions confirmed, all the materials on hand, and need to start making some simple tooling. Stay tuned!
