i have kubota b2150 took out ignition switch tool to locksmith to remove part of broken key .came back home put back in and nothing. no power no light no glow plug indicator comes on nothing replaced 2 10amp fuses battery is charged. but nothing the only thing that seems to work is blinkers. is there another fuse somewhere or was my ignition switch messed up the locksmith did squirt oil inside i think he used wd 40 .is there a way to check or troubleshoot problem. i dont have a seat switch as far as i know and yes clutch switch is depressed when i try to start. any help advice welcomed.
