B1700 Help
simpson1
l4240 and b1700
Feb 7, 2017
27
Iowa
I just got done replacing the pivot seals and re-sealing the bi-speed box. I started it up today for the first time, put it in drive and I feel a bind coming from the front end. The front wheels would just lock up. Just to double check, I jacked the rear up and gave it throttle, rear wheels spun fine. I don't know whats wrong with it. I did all of my testing in 2WD. I don't dare want to try putting it in 4WD to see what happens. I don't know how this could be messed up because before I sealed everything up, I spun every thing by hand and it all turned freely. I had bi-speed turned off when I did this, well at least I think I did. How much of a range of movement should the linkage arm for bi-speed move? It doesn't appear to move a whole lot but it feels and looks normal. I feel somehow where the driveshaft connects to the axle is bound up. Also, I replaced the roller shaft assembly and the new part was smaller but my dealer told me thats how it should be since its and updated design. Any advice?
5,345
The front axle should not bind regardless if it's BI speed is Engaged or not.
Jack up one front wheel at a time and see if it's both sides are binding or just one.
simpson1
l4240 and b1700
Feb 7, 2017
27
Iowa
They only lock up when you try and roll both wheels in the same direction at the same time.
5,345
When you hold one and turn the other does the drive shaft turn?
5,345
You have something wrong in the front end, your going to need to reverse what you've done and find out what part is binding. ;)
simpson1
l4240 and b1700
Feb 7, 2017
27
Iowa
Yea. Could it be in the shift fork? I can turn the axle but the other side turns the opposite way so I don’t think the pinion gear is seized.
5,345
That's only the differential spider gears spinning, not the ring and pinion.
If you only lift one wheel off the ground and can't get that wheel to spin the driveshaft, then the ring and pinion are not spinning. ;)
simpson1
l4240 and b1700
Feb 7, 2017
27
Iowa
I’m not the most knowledgeable with diff stuff but you guys get the point.
