Average hours per year on your tractor
armylifer
Mar 26, 2013
2,319
1,076
Thurston County, WA
That is probably true for models with the electronic dashboard, but for those of us fortunate enough to have an older mechanical tach it is specifically labeled "hours x 1000 rpm".
Does that mean that you rack up the hours faster if you are running at 2000 RPM? Something does not make sense there.
mendonsy
B7500HST/LA302
May 28, 2012
363
38
Mendon, NY
Yep, that's exactly what it means.
Most tractors use PTO rpm to calculate hours, but my B7500 doesn't. It measures hours per 1000 rpm. At idle it logs about 1/4 as many hours as it does at PTO speed.
The hour meter is geared directly to the tach cable so it logs an hours based on the number of rotations that the cable makes. That is the way all mechanical tach hour meters work.
L35
Jun 13, 2010
703
827
CT
Just X1000. Because the tach numbers are single digits
armylifer
Mar 26, 2013
2,319
1,076
Thurston County, WA
Yeah, I'm thinking not. My tractor idles at 1400 RPM. I think that you need to do a little more research concerning how the hour meter racks up time. L35 got it right with his concise explanation of what the X1000 means.
jbbepic
54
Pittsburgh
My l4701 had 4 hours on it when delivered in July of 16. It now has 41hours. The hour meter seems spot on. I timed it one day with stop watch because every time I started it, it felt like boom! 20 minutes. So i checked it , but it was right. Time flies when having fun on it. That story about the cows is pretty funny!
mendonsy
B7500HST/LA302
May 28, 2012
363
38
Mendon, NY
Not all... My 70's vintage IH 574D states on tach "hours at PTO rated rpm" which is 1,850 rpm.
Yep, most older tractors are that way. We have had several IH and Case tractors in the past like that. Kubota seems to be the exception to that rule.
bearbait
Dec 9, 2011
4,189
947
New Glasgow Canada
Bought mine in December 2014, has around 370 hours on it, mainly used for running beer from the house to the garage and a little road work and snow removal.:D
7,318
That'll work, been called worst.
I say that a lot, and it's true.
I was a Health Inspector for many years - got called many things.:eek:
Some even I didn't understand, and I'm good with the English language, slang, and bad words. :eek:
Most can't be repeated here.:p
I do about 50 hours per year on my BX2360.
Use it all year with snow, then driveway/dirt work in spring, then mowing, then driveway/dirt in fall, then snow again.
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
BX25D. Bought it in August of 2014. 940 hrs.
That built me 1800' of driveway, about the same of trench 5 - 6' deep, cap and fill septic system...270' of drain field...and lots and lots of brush clearing and digging a massive side of a hill out for my friend's 48' by 60' barn.
Two HST fans. A couple of FEL pins. Bent the front steering brackets and replaced them. New driveline boots. Removed all the safety switches and operator presence stuff. Replaced the tires...rears once, fronts twice...now they have inner tubes. New ball joints. Front tilt cylinder on the FEL has been rebuilt twice...end of the ram keeps shattering. And all the oil and filters...
Added an emergency starter bypass switch. Skid plates. 3" wheel spacers. LED lights on top and a switch box.
-Mac
OBKubota
2014Gr2120,Gr2728Snowblower,Gck5GrassCatcher,agri-FabSpreader
Oct 21, 2014
205
Ontario
About 600 miles a year ,100 hrs a year /top speed about 6mph lol.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Bought my B2650 new in June of 2015. 470 hrs and has been a workhorse.
bearskinner
Sep 1, 2014
926
242
N. Idaho
Got my BX 25D in August 2014, I'm at 240 hours now. So approx 110 per year. Lotta backhoe work, and snow plowing each year.
Benhameen
Jan 27, 2013
713
135
Southern IL.
318 hrs on mine. Had it 4years 2 months. So 6.36 hrs per month on average.
Although, I bet I put the first 200 hrs on it within the first 6 months. Couple different reasons for that. Biggest one was that my ex and I were still together when I bought it, so there's that....2nd, I did all the stuff I needed to do with it when I first got it. Mostly because of reason number one.
I mostly just mow my yard with it now.
mport
2013 B3200 backhoe
May 9, 2014
27
ST. Clairsville OH
If you had to replace that many parts on a BX25D in 940 hrs, I must be a hell of a lot easier on my tractor. I have yet to replace a single part on my b3200. I have about 700 hrs on a 2013.
