Attachment for gravel driveway maintenance
speedymph1000
65
Alabama
I'm considering getting one of these to maintain my gravel driveway:
http://www.everythingattachments.co...-Scarifier-Rippers-p/eta-land-leveler-ws-.htm
My driveway is about 15' wide and I have a L3901. Which size leveler would the L3901 be able to handle well? I was thinking that the 5' model would be a good choice?
I pull a 6' LMC land leveler with My L3901 HST.. I pull it in 2WD up and down hills and never have any trouble. Even with the scarifies down I never have traction trouble with R-4 tires. I feel like I could go to a 7' or maybe even a 8' without trouble.
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
I've been pleased using this:
http://www.tractorsupply.com/tsc/product/countyline-landscape-rake-5-ft-w
My 800' driveway is recycled asphalt millings and I understand its much like crusher run gravel. When angled the teeth line up to form a "blade" like implement permitting me to maintain my crown. While I'd love a landplane for other uses I wasn't sure how to retain the center crown.
eipo
L4060
Dec 1, 2015
699
85
MI
It will somewhat naturally maintain a crown.
But you can also manipulate it by adjusting the 3 point arms so the outside edge arm is lower than the inside.
sent from a field
afret
L3901, MX5800, U55-4
May 7, 2015
167
North Idaho
Called Everything Attachments and they pretty much agree with your findings. They said get a 6' or 7' and the L3901 won't have any problems pulling it. Went ahead and ordered a 6 footer. Thanks for the insight.
And everyone, thank you very much for your input!!
Wyoming BX
BX25D, box blade, pirana teeth, B2781 snow blower, 3pt trailer mover, rear blade
Jan 29, 2016
9
Casper, WY
You should be able to pull a 7' easy. I built a 54" land plane and put a 55 gal barrel on it for weight. It probably weighs 7-800 lbs and does a super job. I have about 3-$350 in it. A land plane works much better than a box blade for maintenance, box blade moves material from one place to another.
I highly recommend building it yourself. Two cutting edges, some pins. some salvage metal and off you go.
speedymph1000
65
Alabama
You'll be very pleased with it I'm sure. Let us know how it works out for You.
torch
Jun 10, 2016
2,816
1,057
Muskoka, Ont.
How is the land plane at dealing with hills in the driveway? I have a considerable change in grade part way down the drive and then it levels out again beyond that.
eipo
L4060
Dec 1, 2015
699
85
MI
I suppose it depends on the severity of the grade change. They don't ride on the cutting edges like a box scraper does unless you have then adjusted down. My drive has a couple decent grade changes and it wasn't an issue.
sent from a field
BigRed57
L2350 4x4 land pride 4ft bush hog
Jun 29, 2016
70
Society Hill S.C.
My driveway is pretty much flat. It has a small hill to climb going out of it but it's a very small one. My dealer has a 96" one but I don't want to buy it and try to make it cut and my tires just spin
eipo
L4060
Dec 1, 2015
699
85
MI
45 horse and 4 wheel drive. I think you'll be OK.
I was skeptical about my 26 horse tractor pulling the 72" and my dealer said if it's to big they'll let me exchange for a 60"
See if they have a demo unit.
sent from a field
