Air Conditioning problems M7060
Kaileebug1
M 7060
Aug 4, 2026
AL
Do you have ground on the W/B wire or the B/Y wire off the controller, when the AC switch and the blower switch are on?
B/y. Should have it on the white black?I know but I don't. I have already swapped controllers, and that didn't change it.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
593
259
CNY
There should be a connection to ground on the W/B wire when the AC switch is toggled on. If not it will not engage the clutch. I would recommend checking continuity between each point in that circuit.
If you ground the W/B wire does the clutch engage?
Kaileebug1
M 7060
Aug 4, 2026
AL
Yes it does. I'm pretty sure the climate control servomotor and the fresh air reciculate is not operating either. Control for mode ( defrost, defrost and dash, or dash vent does operate.
Kaileebug1
M 7060
Aug 4, 2026
AL
But yes the way I understand the schematic, the white/ black stripe should be grounded from black/yellow stripe through the controller. I dont get it
#40Fan
673
499
When checking for power, did you check it with the controller plugged in?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
593
259
CNY
If you don't have ground on the W/B wire but do on the B/Y wire when the AC switch is turned on then you have an issue in the controller. The fact that the AC switch LED does not illuminate tends to indicate this. You are toggling the AC switch on and off while checking correct? Have you induced or connected a ground to the W/B wire and checked if the clutch engages?
Kaileebug1
M 7060
Aug 4, 2026
AL
Yes i jumped the ground from the black with a yellow stripe over to the white with a black stripe and the compressor comes on. Still no illumination on the AC switch or recirculate switch or anything, but the compressor does come on when I do that.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
593
259
CNY
The only logical conclusion is there is an issue at or within the AC switch in the controller. The AC and F/Rec LED indicators are on a different circuit than the AC switch to thermo amplifier so It could be multiple things wrong.
Kaileebug1
M 7060
Aug 4, 2026
AL
To close this article out I found the problem finally. The tractor was under warranty and the dealership tried to resolve the issue to start with claim they tried three new controllers on it and still didn't help. I checked all the wiring check the harnesses the connections and the controller with my multimeter and came to the conclusion the controller was bad yet again they told me they've done tried three controllers on it even gave me one to try. Turns out it was a bad controller just like I told them. Anyway issued solved.
#40Fan
673
499
That would mean four bad ones? One you tried, three they tried? Finally the fifth fixed it?
New does mean, never ever worked.
Fedup
377
149
Winchester
There was a time when tractor cabs had a simple mechanical temperature control switch. You could decide if it worked or not in thirty seconds, find a replacement if needed at any parts house. Now we have "controllers" that can't be tested other than by replacement, a half mile of wires, servo motors, all sorts of doo dads you can't get to without taking half the cab apart. Modern stuff is so much better.
