Adding gages
flogler
2017 BX23s
Dec 18, 2019
55
Debary, FL. USA
Looking at installing gages on the BX. Thinking of engine oil temp and hydraulic oil temp. I have a tripod set up so what would u think a 3rd gage would be if you had a choice?
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
242
49
Southern IL
Assuming tractor has coolant temp gauge, my choice would be ammeter, engine oil pressure and Hydro temp.
But I'd have to want it pretty bad to go through the trouble of installing all those.
But hey, it's your ride...make it yours!:)
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
Amp meter is kind of a pain in the but to wire. Volt meter is a cheap and easy alternative to let you know if your battery is charged up or getting ran down.
5,286
Adding ammeter as the 3rd is a no brainer. It's on my 'todo' list, along with building a REAL grille guard.
A voltmeter is a low buck 'cheat' and I've tossed them out of the rest of the tractors and wired in real ammeters. A voltmeter only shows the 'surface voltage' of battery or alternator output NOT the actual flow of electrons ( current) going to/fro the battery. It's in the same catagory as TPMS...
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
Knowing myself, I'd opt for a level like Jeeps have so I know when I'm upside down.
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
Yeah I'm wiring an amp meter now. The alternator wire went from the alt to the batt was about 18 inches long. Now it runs from the alt to the dash then back to the battery.
