A rant
lynnmor
B2601-1
May 3, 2021
1,786
1,595
Red Lion
You need to grease the right palms. Safety inspections are a scam.
shop around... there are probably 100 places to go in your area.
Worse case, You can do ball joints in an afternoon.... for the cost of a case of beer.
Did you test the ball joints yourself?
I could write a book on the faulty crap from Pennsylvania State Inspections. One example: Ford dealer wanted $700 to repair my dragging front brake saying warranty didn't cover it because it was rust. I took it home then cleaned and greased the caliper pins, there was no rust. The idiot bent my brake line so that the hose rubbed the coil spring so he could use power tools on the bolts. The idiot could have killed me, maybe he was the one that put 2 quarts too much of the wrong oil in the engine.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
At work we had three different F150's spit a spark plug and tore out the threads. Repairs - all in round numbers - at our trusted local garage were $1K. They took a week because they broke a tool off in the head. It wasn't easy to switch away from this shop because our COO had a "relationship" with that shop owner and had his personal vehicles taken care of there.
Stocker Chevy in State College charged $500. A small shop 10 minutes from our headquarters recommended by a friend (Nate's Automotive) $250.
Part of my job was handling vehicles and Nate's ended up with essentially all of our work for vehicles in our area. Our projects were spread out across a good part of PA, so when we had good experiences with dealers like Stocker, we kept using them.
9,117
That 15K is real low in my area. ever since 'Walkerton', installers have been gouging , typically 35-45K for a septic system,takes all of 2-3 days. Next door would have been >$50K until I asked WHY 2 pumps, 3 tanks when GRAVITY works just fine....
as for ball joints, check Rock Auto for them, next day delivery and say $150 per hour X 4 ?
Thats why I shopped around. My system uses a pump for the liquid. But my leach field is 150ft from the house and up a hill.
Neighbor behind me had to basically install a mini sewage treatment plant because his ground wouldn't perk. (I'm still not sure why he couldn't install a mound system)
Anyway, his system still came in quite a bit under my first bid of $15k. His cost a little over $10k for installation.
His system has one pump, to transfer the liquid to the tanks. Liquid goes through 4 separate chambers. Each chamber has an aerator in it.
Once it enters the first chamber, gravity takes over. Once one chamber is full, water flows to the next chamber.
5,436
Boys Im sure I could find everything at auto zone or rock or another supplier. Problem is at least around here another shop wont touch it after it has been flagged by a dealer. And I am no longer in shape to do things at home any more. Old sucks! I guess the pint I was getting at is the insane prices charge for parts and labor, since that money does not go to the guy working on it. I do thank you guys for the input guys :)
7,316
@skeets - - sorry to hear that. Hope you drove away.
In New Yorkistan, ball joints aren't even part of an annual inspection. Gotten so it's all plug it in to check emissions/check-engine lights, etc. - don't think they even need to pull a wheel anymore to check brakes. Always had to pull one wheel.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
551
183
NZ
So they have got you by the gonads. Is it a federal, state or county or what sort of rule? I'm interested because what happens in US, Europe etc tends to percolate in this direction. Here, with the cost of living already high, there would be a riot if that was imposed.
I'm sorry to hear that. If you haven't already thought of it is there someone else - like a trusted young adult - you could get to do the job, coaching them for free? Yes it'll take 4x longer and a lot of patience but you can get the satisfaction of passing your skills onto someone else. Preferably starting on small simple jobs, building up. I'm incapacitated at the moment so I'm using a 17 y.o. we've known since he was a pre-schooler to do various jobs. Not all of them have faces buried in devices all day. And they don't necessarily have to be male, some excellent women too. What they might lack in strength they make up for in thinking stuff through, other ways.
5,436
John DB well I did have a grand daughter working with me on the bike, and she was small enough to get under the truck to change oil with out jacking it up,, my belly would get in the way, ,lol But she grew up got married and old grand pap is out of the picture. Her hubby was up set because I patched her tire that he said couldnt be patched. I dont know any young kids any more, they all grew up dayum kids ;)
7,102
Thats crazy. If you fail a state inspection here you can have it repaired anywhere or DIY and the inspecting station does a reinspect of the repair for a nominal fee. WTF do you live?
6,896
Agreed. I had a PA state inspection license for many years. I've never heard that you couldn't take required repairs elsewhere (or fix it yourself). Yes, you'd be on the hook for the re-inspection labor charge if you were to take it back there. But the notion of no-one else can work on a vehicle that's been "flagged" by a dealer is a blatant lie. That's a whole lot of bologna right there...someone isn't telling the truth there.
Just sayin'
Scm
BX23S
Sep 28, 2024
386
386
Missouri
Some states are eliminating inspections. Some stations are holding people hostage with crazy repair bills. Its just another scam.
7,102
You cant hold people hostage in a free market and thats what we have here and in every other state I have lived in.
I live in MD and the only state safety inspection required is when you title the vehicle. That may sound like a good idea but when you see some of the junk on the road next to you not so much.
Spam Bot
Windows Computer
Aug 3, 2024
179
129
Austin, Minnesota/Key West FL
Stories like this make me extremely happy that I purchased an extended factory warranty from the Ford dealer after the first extended warranty expired. Now my 2016 is covered till 150,000 miles or April 2028. It cost me just over $ 3,000, but it was money well spent. Two months ago, they replaced the tie rods and the steering rack, and my cost was $50.
WI_Hedgehog
Apr 24, 2024
1,128
1,645
Milwaukee, Wisconsin, U.S.A.
$4,000 is nuts. I'd buy a impact-driven ball joint press and Milwaukee cordless impact and have at it myself just from spite. I'm old enough to be fueled by anger and caffeine, and mean enough to kill the pain with whiskey.
But I do make bad choices.
7,102
I dont own a Silverado and I could be wrong but I think its just like my Ram.
The upper ball joint is integral to the control arm. You replace it as an assembly - remove the wheel, two bolts, one nut. The only tools needed are a ratchet and a pickle fork. Two replacement control arms are $150-$500 per pair depending on the nane on the box.
  • Sad
7,316
I've had many people tell me that "I took my vehicle in for an inspection, and they said they wouldn't let me drive it away...."
Often women.
Once was my wife.
My usual advice was to tell the shop...."Watch me drive away......See ya....." ;)
7,571
When I've been to a shop (dealer or not) I get the repair parts cost and the labor cost. Then tell then I'll check my funds and see if I can afford it right now, if I consider them out of line. They don't pressure with stupid necessity repairs if they know money might be an issue.
JohnDB
Jun 9, 2018
551
183
NZ
Predatory pricing in all its forms really annoys me.
Sounds like in @skeets area the local shop/s have a cartel going.
So he could:
1. Get whoever told him that no other local shop can do the work and record that conversation.
2. Check the other shops to see if its true and record that.
3. Report it to the FTC Bureau of Competition and/or DOJ Antitrust Division
Simpler solution: borrow @WI_Hedgehog 's drinking buddy and send her around.
chim
Jan 19, 2013
3,278
2,976
The shop I've been dealing with for the past few years has already asked if I wanted to do work on the vehicle or have them do it. The last time the Trailblazer threw an evap code while doing the PA inspection, they had me drive it for over a month to see if it came back or was cleared. I finally called them and said while I appreciate their generosity, I at least need to pay the cost to date. While there I scheduled a drop-off date for them to really dive into it. This is in the same PA but not in the big cities.
Yooper
3901 LA525
May 31, 2015
1,731
909
NE Wisconsin
Something seems off here. I thought state inspections were for emissions and DOT stuff. Might want to look into that. Secondly, the lower ball joints are usually the first to go, not the uppers. How many miles are on your vehicle?
Maybe a ‘second opinion’ vehicle inspection would save you a whole bunch of money and headache!
One last thing, how does the truck handle?
