!5-40 Rotella oil
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
Yes, I think 15-40 is only for hot areas (country) Did a test and plugged in the block heater at 40 f. No click kacking or metal noise. Seems to be as smooth as the old 10-30. What do you think.
3,088
Mine starts easily over the whole temperature range, even as low as -15f, (and once at -31f) and I like the protection of 40w when it is hot and I am working it hard all day long.
flyidaho
L 3301 HST
Feb 28, 2017
428
253
IDAHO
When I noticed my local Costco carries a Kirkland/in house brand of oil, and the price, I started using it a couple years ago in my Mack crane truck. It takes 56 qts. every change! Oil tests since using it got me from 350-400 hours between changes to 750-800 hours, based on the lab reports. Over the 5 years I've been a Costco customer, I've become something of a fan boy of the company.
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
Yes, I have been a Cosco fan for 25-30 years.
BobInSD
L5740
Jun 23, 2020
372
126
South Dakota
If you like Rotella T6,use 5W40 as all your bases will be covered.
You do not live in Fairbanks or Flagstaff.
Good Luck!
I live in a colder winter climate and I'm trying Rotella T6 5W40 this year. Haven't had it in during winter yet, but nothing seemed to change using it over the summer. I do not work my tractor nearly as hard as many do.
BobInSD
L5740
Jun 23, 2020
372
126
South Dakota
All I could find at Wally was 15-40
I hate to say it, but maybe Wally knows best? Or at least what sells where? The 5-40 was on the shelves at the Wally World here. There was at least as much 15-40, but the 5-40 was available. Mine calls for 10W-30 but I don't even know if 5W was a (common) thing when they built it 12 or so years ago. I know I've started using multi-grade on air cooled engines, which was a big no-no when I was younger. It seems to be OK?
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
I won't be using 15-40 without a block heater here in Southcentral Alaska which is about the same clime as Minnesota. In Northern Alaska where I use to live 5-30 or lower.
WFM
L3800
Apr 5, 2013
1,452
860
Porter Maine
Rotella T4- 15w40 since new. And we do get some cold weather here in Maine.
Anything about 10*f or less I'll plug in the block heater for a hour before starting.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
365
514
SE, NM
The splash oiled engines needed ND oil, most common was 30w. If you have an air cooled engine with a pressurized oil system then multi-grade HD oil is probably what's recommended in the manual.
BobInSD
L5740
Jun 23, 2020
372
126
South Dakota
We do see -30 here, but I hope to never have to run the open station tractor below -10. Kubota says 10W-xx below freezing. We're well below that so I'm looking forward to seeing how the 5W-40 works (well, not looking forward to the testing at temp, but looking forward to finding out)
Thanks I was not aware of that distinction.
nbryan
Jan 3, 2019
1,302
825
Hadashville, Manitoba, Canada
I get -30C (with coolant block heater) to +30C starting temp range here in S Manitoba and the first few changes used the recommended 10w-30 Kubota oil, loath then as yet to use anything not explicitly recommended in the new tractor's maintenance manual.
I had read here of T6 5W-40 doing well in these engines. It turns out we had an old VW TDi (long since retired) that had thrived on t6 5w-40 and I had exactly 4L left in a 19L pail sitting there in the garage melee. In it went at the B2650s 400 hour service.
I certainly noticed "easier" cold starts, whether biting cold or around freezing, in that it quieted faster from the initial always present diesel rattle bang cold start noises. Idle smooths out and quiets faster.
And honestly the power and responsiveness using this oil compared to the Kubota 10-30 semi-synth seemed better.
Makes sense to me, with the lower start viscosity 5W vs 10W, and higher run temp viscosity 40W vs 30W.
"Coverage" is enhanced at both ends?
I'm hoping to hear from more knowledgeable on this, as oil can be a hot topic here and it's interesting to hear more from those better versed.
But the T6-5w-40 does a better job here in both heat and cold than the 10w-30. And I wouldn't go near a 15W- as starting temps don't go above freezing here in the morning for 6 months of the year.
jyoutz
Jan 14, 2019
3,376
2,412
Edgewood, New Mexico
I have been using 5W-40 Valvoline in my truck with Cummins motor for years and have noticed much better cold weather starting and operations. It was a no brainer to use it in my MX when I did my 50 hours service. 10W-30 is old school adequate, but the synthetic 5W-40 is a huge improvement.
5,155
Cummins actually requires 5W40 in some of the newer engines. Use of 15W40 at reduced (<0C ??) temps has been shown to cause failure of the high tech valve.train.
Now should I stir the pot by mentioning the one "concerning" performance difference in the two viscosity specifications. As the old saying goes there is no free lunch.
jyoutz
Jan 14, 2019
3,376
2,412
So tell us the concern.
