4610 hst pedal slow returning to neutral
mopar2ya
104
ontario canada
My 4610 forward/reverse pedal is slow returning to neutral position. I blew linkage with compressed air to remove dirt, I used penetrating oil/grease on all fittings and tightened tension spring. It did not make much difference. Am I missing something??? thanks
Michigankubota
B2650 Loader,LX 2980-64 Blower ,60”MMM , Land Pride 60”Box Blade.
Oct 17, 2018
246
14
Bessemer, Western U.P.
My BX2670 is the same. I’ve adjusted the spring tension which helped the peddle return a little faster. I guess I just am more acquainted to it now compared to my belt drive JD lawn tractor with Hydro drive.
rbargeron
Jul 6, 2015
1,181
258
western ma
The 2-way damper on the linkage is supposed to add controlled spring force for neutral return too. Maybe its getting weak or sluggish? (like me? :eek:)
8,778
Disconnect the dampaner and see if it speeds up significantly, if it does you need to get a new dampaner. ;)
