3rd function and grapple vs FEL with thumb
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
Need input! I have 20+ acres of woods. I thin and cut 7+ cords of fire wood plus have numerous (on going) slash and brush piles to clean up. I need to decide on grapple or FEL with tooth bar and thumb. I have a B2620. Need the FEL a lot and right now am thinking the thumb may be the ticket. Already have the FEL.
7,243
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
257
47
Sandpoint ID
www.gemstarcustoms.com
Let's get all us PNW guys on one thread :D
I gotta agree with Wolfman, if the money is available the grapple makes working with wood much easier..
Plus it is better at ripping stuff out of the ground like roots and runners
sawmill
bx24 backhoe/fel, 48" Bush mower
Nov 16, 2014
571
142
ione, washington
I agree on the grapple also. Years ago I built several of them for loggers, to go on there skidders. They used them for moving brush to slash piles.
Tooljunkie
May 13, 2014
4,150
We used two skidsteers with grapple buckets to cleanup brush and pile wood,ended up with 300 estimated cords. The brush piles we burned were massive. All spruce and pine. Tooth bar and grapple as wolfman showed would be my go to tools. Very nice for sorting, but a little slow with a tractor (turning and manuvering)
Run what you have....
pendoreille
Jan 2, 2015
476
Newport, WA
we seem to be in the same Pend Oreille drainage....and snow belt. a little lite this year, normally 5+ feet and I might have 18'' on the ground. member 96 - 97 my 6' deer fence was just a bump in the snow
thanks for all your input, with a grapple I might run out of seat time
gssixgun
Jan 5, 2013
257
47
Sandpoint ID
I heard about 96/97
We moved up from CO in 02 so the biggest winter we have gone through so far was 07/08 and yep that easily buried the 6 foot fence and more...
You are close enough that you should check the prices at North Idaho Implement for the grapple set up..
pendoreille
Jan 2, 2015
476
Newport, WA
I heard about 96/97
heading over there maybe next week weather the way it is may need it sooner than later, turkeys starting to get color thanks for input
