I've just bought an L1501. It looks great and runs well, but I'm a bit confused.
The front cowl says it's an L1501, as does the plate on the side of the chassis near the clutch pedal. The problem is that all the data I can find on the L1501, or the L185 equivalent says it should be a 2 cylinder motor.
Mine has 3. At least it looks like it has 3. I have attached a couple of photos. The left side of the engine block is stamped K2 40109. The right side has 1115cc. The serial number on the "caburettor" (is that what it's called in a diesel?) is Z750-48645. According to my research the Z750 is also a 2 cylinder. Finally, on the top of the engine it's stamped K3-A.
So I'm trying to identify if this is a variant on the 1501, or if it's a refit with a different engine. Mostly I'm just trying to identify it so that I can get parts into the future. I'll need a fuel and air filter in the not-too distant future.
Thanks for the help!
Mike.
Mike.
