rkidd
Thought I would take a minute and share how good these Kubota tractors are. I have put more than 2100 hrs on my tractor. The old timers on here will know I am a retired heavy eqiupment operator and to share with the new people on this site. Bought my tractor new in spring of 2015 with loader and 60"mmm. I average 250hrs a year doing all the task on my property from mowing, brush hogging, rototilling, grading, and snow removal. Implements I added are FDR 1672 rear finish mower, BB1572 box scraper, RTR 1266 rototiller, 72" landscape rake, 48" pallet forks, and Bush Hog Squealer 60" brush hog. Some of these implements per spec might be over sized for the tractor, and would not recommend for inexperienced tractor owners, but the tractor handles all of the great or I would have replaced it. I always buy service manual with any equipment I buy. It came in handy to track down the only porblem I have had with this tractor in all of these hrs. The neutral safety switch went bad and was able to trace the problem down. Replaced switch and has been fine ever since. The mods I did to enhance the use of the tractor are, 3 bucket hooks on the loader bucket, install a bolt on cutting edge on the loader bucket to strenghten it and allow replacement when it wears out, fab up a tool box for chains and straps, install LED lights front and rear for snow plowing at night, rear view mirror for roading tractor, and the best one of all is top and tilt for hooking up and using implents. Absolutely would not have tractor with out it. I actually did the top and tilt my self buying double spool valves and both cylinders from Surlus Center. Fabbed up brackets and mounted valves and cylinders and loaded up tractor and hauled out to my Kubota dealer who I actually helped for couple seasons, to measure and get all the hydraulic hoses made up. Really handy for hooking up implements, and angling box blade front to back and tilt left and right. Can actuall run it similiar to a bulldozer. Another handy thing with brush hog on is to tilt back of brush hog up to back up over big briar bushes and set down on them to chew them up. I do follow all of the maintence procedures always using Kubota fluids and filters with no problems at all. In summary could not be happier with my choice, Tractor had been flawless and does more than I thought for its size. Some how couple years ago all of my pics from all my posts got deleted which was really dissapointing as it is alot of work to do. I will post a couple of pics after this post.
