Hey folks....Haven't been able to find this issue on the forums so I figured I would start a new thread. The swing shift (32 speed transmission) has been acting up and not going to the turtle (low side) when I would swing the gear shift lever. The light will switch to the turtle but the short beep that normally happens is just does a constant "beep" until I hit it again and it goes back to the rabbit (high side). If I do it 4 or 5 times, it will finally beep normally (sometimes) and stay on the turtle. Never have a problem going from the low side to the high side. Also, while it is constantly beeping and the turtle light is on, the transmission is still actually on the high side. You can put it in gear and drive it (high range) but the turtle is on and the beep is constant. Any ideas? Thanks in advance!
