2.5 gal YELLOW fuel can? (maybe Orange?)
2,721
I'm told that these are a factory Kubota B7100 part, not sure if the are still available, but here is a pic I found. Slows the pour, but nice to know nothing is getting in the tank.
A quick check with Coleman's shows it's still available.
2,721
Well, ordered on Monday and received it on Wednesday. So much for Covid delays.:)
2nd pic is with it's 5gal big brother.
Magicman
Oct 8, 2019
5,595
7,868
Brookhaven, MS
knotholesawmill.com
I found those 5 gallon Scribner jugs a bit awkward because of the handle location. There is an indention on the bottom which helps but I still always seem to be hugging it. I now only use the orange ones for Diesel storage at the farm, but the green ones get regular use as my sawmill lube (soapy water) containers.
2,721
I like the green ones- never seen them with color matched caps. All mine are black or white.
Magicman
Oct 8, 2019
5,595
7,868
Brookhaven, MS
knotholesawmill.com
The green jugs came with green caps and I later painted the white ones on the orange jug......orange. ;)
NHSleddog
B2650
Dec 19, 2019
2,149
1,836
Southern, NH
My thinking is that you will get much more water condensation with a partially filled fuel tank. Both of my tractors as well as the sawmill are always filled to the top at the end of the day.
That is a great practice. I do the same as well as grease everything. This way there is no fresh metal to get wet at night and no getting smelly/dirty first thing in the morning.
BobInSD
L5740
Jun 23, 2020
366
123
South Dakota
I'm guessing the spendy "spill proof" nozzles will only fit their cans? Somebody said they have a wider opening, so this is probably the case?
I like, and am stealing, the "platform" on the loader arm idea but am having trouble wrapping my head around $35 plastic fuel cans. I also have lots of gas cans that I've put vents in, maybe I'll just paint/tape a few of them yellow. Right now I re-purposed some of my daughters yellow and green hair ties to wrap around the handle when there is diesel in the can, but need a more permanent mark.
2,721
Got to try my 2.5 gal orange can today and I love it!
Easy to fill from the 5 gal can, very easy to lift, and very controllable when pouring into the tractor filler neck.
I'm going to call this a big success.
Mark_BX25D
Bx25D
Jul 19, 2020
1,785
1,301
I cheat. I use a 12v pump. I figure it was free, because I bought it to pump out a half-full home heating oil tank. I got the tank and the oil for free from a Craigslist ad. That's over a hundred gallons of #2 diesel. Yeah, I think that pump paid for itself! :)
I plan to pour a slab and set the tank up on it, then install the 12v pump with a filter setup, and a high power quick disconnect to plug into the tractor.
I also use one of these for the 5 gallon pails, when needed:
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
213
45
Dickson, TN
Because I'm not as tough (or young) as I used to be, fueling my B7100 with a 5gal fuel can is a PITA. In addition to having to hold up that heavy can, I must reach over/past the FEL, and the filler neck of my tank has a fine strainer screen, so it must be filled very slowly. I think it would be much easier if I can get a 2.5gal (or 2.7gal) fuel can like this:
https://www.cyclegear.com/accessories/tuff-jug-utility-jug
My problem is I cannot find this smaller style can in YELLOW; every other color, but not in yellow. (for diesel) I might have to buy one in ORANGE, for Kubota.
Any body know a source? Thanks.
How about pre-straining your fuel into a smaller jug then not using the strainer when in the awkward position? That way you can still buy 5 gallons at a time and save trips to the store. And a funnel in the tank goes a Long way.
2,721
In post #69 above, the smaller can works quite well, and when I need more fuel, I fill a 5 gal & the 2.5 gal can.
dvcochran
Feb 23, 2011
213
45
Dickson, TN
Okay but strain on the ground where is it much easier.
2,721
OK, gotcha. But there really is no strain with the small can, and it is very easy to lift & control. Hardest part now is lifting the 5 gal can into the bed of my F350 after filling.
