Final modifications as family time approaches.
Cut 7” square openings on the sides where the fan cooled alternator blows to discharge warm air.
Installed 345cfm rugged fan on the back directly blowing on the alternator and gearbox. 40 watts, ball bearings, metal housing and guards. GDSTIME Axial Fan 17251, 110V 120V AC 172mm x 150mm x 51mm Dual Ball Bearing High Speed for DIY Cooling Ventilation Exhaust Projects
https://a.co/d/5NUKNI5
Probably don’t need fan for temperatures <70F but easy enough add. The way the lid is made have nice overhang for rain protection.
Ready for all weathers.
The trash container makes for sturdy, nearly indestructible, lightweight, easy access cover. Providing protection during use and storage. Preferred by bears like me 9 to 1.
Conclusion.
If you have a tractor, a pto generator can make a lot of since. Much of the generator maintenance and fuel issues are already covered. Disappointed that my used generator voltage meter was not working correctly. Did provide the necessary opportunity to upgrade meters that give a better measurement of performance and accuracy. The cover not only provides protection while stored but also during inclement weather at multiple houses and buildings where it might be deployed.
