#1 missed maintenance item
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,171
1,161
E.
so our retired farmers club (our morning meet up group for coffee and pie at local diner) consists of our group of over the hill farmers. We talk / argue / fight over all kinds of things prior to starting our days work. non of us overly educated / some days our table is full and counting years of experience we often get near 1,000 combined years of farming experience across the group. It amazes us.
today the topic was delayed / missed maintenance on our equipment.
what kind of maintenance (preventative/seasonal/other) is most often missed by your hired help / family members?
seems like we are seeing a lot of fuel issues these days as bio-diesel is creeping onto more yard sites. given we get petroleum only diesel delivered to our yards I never thought this topic would kick up such a hornets nest of hate. I just didn't know as I rarely ever get exposed to bio diesel.
So Kubota says no troubles using up to B20 but:
- replace fuel filter every 200 hrs
- replace all fuel lines every 2 years
- If using up to B5 drain fuel tanks and replace with fresh every 3 months, and if B5 to B20 is used then the tractors tanks should be drained every month! so an extreme keep your fuel fresh approach is needed. Must be hard for guys that don't run a tank of fuel a month or so.
our local dealer e-mailed me the following clip and I had no idea. no wonders so much fuel related problems are surprising guys.
I got schooled.
armylifer
Mar 26, 2013
2,326
1,082
Thurston County, WA
You may get arguments from some people concerning bio fuels but they are recognized as unstable by most government agencies that depend on their emergency fleets being dependable. Even the US Army used only straight non-bio fuels when I was in the service. I don't know what they use these days but I suspect that it is the same. Bio fuels are just a plain bad idea.
Bee-Positive
Nov 16, 2022
1,059
986
Amsterdam, NY
I can see why you "poked the hornets nest"
I'm a complete "knob" when it comes to diesel fuel (and most other things) so be kind with your answer.
Here's my (derailed) train of thought.
Local gas stations sell ethanal gas at some percentage almost exclusively.
I get my diesel from the local gas stations, granted only 10 gallons every couple of months.
Is the diesel they sell straight petroleum or could they incorporate some % of bio mixed in.
And would they have to label it on the pump as such like they do with E-gas?
JasonW
810
558
Al
All my local stations have a sticker by the diesel pumps that state Up to 20% biodiesel. So it could be 0% or up to 20% at any given time.
I have used diesel that has sat over a year in my transfer tank with no issue, on several different machines including my truck. Although it was treated with Power Service or Hot Shots Secret.
armylifer
Mar 26, 2013
2,326
1,082
Thurston County, WA
In my state they used to have to label any pump that had B5 or above. However, some years ago they changed the law so that they only have to label B20 and above. If you want to know what you are getting for sure, you will have to ask the manager what they are ordering. Even then it is questionable as to what you are really getting if you are buying from a convenience store. You have to purchase from a major dealer to really know for sure that you are getting what you want.
Bee-Positive
Nov 16, 2022
1,059
986
Amsterdam, NY
Being NY State I imagine they'd have to label it.
I just never thought to look but sure will next time I fill up.
MapleLeafFarmer
Dec 2, 2019
1,171
1,161
E.
It can be confusing.
first pic is #2 with undefined bio content, next 99% bio diesel from this pump, then 20% from this pump, and finally these guys say somewhere between 5 and 20% but wont tell exactly. Confusing? My supplier has reg. and premium diesel, no bio to farms, blended #1 and #2 depending on expected temp. but won't say exactly.
  • Sad
armylifer
Mar 26, 2013
2,326
1,082
Thurston County, WA
Two of the problems with bio-diesel are it's acidic nature and the fact that it is extremely hygroscopic. The feed stock used to produce biodiesel is what causes acidity in the finished product. Not all biodiesel is inherently acidic but one cannot know for sure what feed stock was used. If it was animal fat based then it is probably very acidic and will corrode the fuel system in time. The other problem is the hygroscopic nature of the feed stock used, whether animal fat based or vegetable based. The tendency to absorb moisture from the air is another cause for corrosion and contamination of fuel systems.
The answer to the question of whether there is a biodiesel additive that stabilizes the fuel, is one that depends on the situation. There are way too many variables involved to give a reliable answer to that seemingly simple question. The best answer that I can give is the simplest one. Stay away from biodiesel if you can.
MapleLeafFarmer
Dec 2, 2019
1,171
1,161
E.
Is there a treatment that stabilizes bio-diesel?
absolutely... there are many that help with microbial contamination.
but there is still the water issue, the increased maintenance frequency issues, fuel hose/filter issues, increased gelling issue in winter, increase soot / oily deposit production in exhaust shortening DPF life and frequency of regen's, etc....
me I have no first hand experience as I have easy access to petroleum only diesel but I am interested in how the smaller diesel volume users that buy from local fuel stations seem to be having fuel issues with little of no knowledge of what has caused. Sort of an up and coming issue in my area and how we probably have to change our thinking on what fresh/clean/safe diesel requires.
The signs seem to be screaming at us around here that if you can not empty your tank every couple of months then special care / attention is needed or problems maybe in your near future. Even the Kubota manuals and our dealer is telling us this but many not seem to be listening.
Bearcatrp
Mar 28, 2023
1,379
997
Minnesota
Have yet to have this issue as I always pour my additive in, year round. After reading the post with the Kubota information, may change my fuel filters. Have owned mine 1880 for 3 years/210 hours and have not changed mine.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
713
831
NE FL
According to my supplier ALL diesel available in our part of FL is at least B5. He says they don't have to label the pumps at B5 and below.
I buy a 100 gallons of off road at a time and store it in a 100 gallon aluminum Freightliner tank. I treat it with Biobor JF upon delivery. Only once did we get cold enough weather I put any anti gel additive in. My usage varies from 1 to 3 tanks a year. It will probably get more to one tank a year since I am finishing up clearing my land and have sold my backhoe. So far I have not had any problems.
I have had fuel related problems I inherited with tractors I purchased. My backhoe had rust issues and my JD had algae but after cleaning both out it didn't reoccur using my treated fuel.
MapleLeafFarmer
Dec 2, 2019
1,171
1,161
E.
that's good info for you to know for sure.
at least to me 5% means more than 5% or B5 or higher inclusion rate??
given the Kubota manuals, this gives you 1 month from its refining until your diesel hits its best before date. Pretty tight time lines for the little guy that doesn't burn a tank a month or is trying to store up some diesel for more than 1 month at a time.
now all this fuel related issues we are hearing about around the coffee shop makes a lot more sense. Its not whether a small diesel user / improper stores has had a problem but more like just a matter of time about when you will have a problem if fresh best practices are not being used..
Glad we get petroleum only diesel on our yard site which gives me a shelf life of between 1 to 3 years depending on how stored and what additives we use.
Never ever had these issues or worries pre 2000 when our diesel had 5,000ppm sulphur for lubricity and we didn't start feeding the bacteria with adding bio. Now the new world thats creeping up and getting worse every year means we need to take much more care or suffer the expensive consequences.
MapleLeafFarmer
Dec 2, 2019
1,171
1,161
E.
historically i have never used / never thought I needed additives.
recently my mind has changed completely on the issue and like you (fingers crossed) I am now using on all off season equipment for sure. In spring/fall my fuel doesn't sit more than a few weeks so not using it then but over the winter and mid summer when my fuel may sit for a month or two I add like you and so far so good. I did notice earlier this year my smaller seldom used L33 was developing "green greasy snot" in the fuel water filter and this was a bit of an eye opener for me. Never seen this before in my lifetime.
armylifer
Mar 26, 2013
2,326
1,082
Thurston County, WA
That green greasy snot is probably algae. That is also something that biodiesel is prone to building up because of the greater hygroscopic nature of bio fuels.
TimAT
GF1800 4x4 60" Mower F2560 4x4 72" Mower Push Blade Fabbed from a JD mower
Oct 5, 2023
51
22
Kansas City. MO
Is there a way to test the fuel to know what you're getting?
MapleLeafFarmer
Dec 2, 2019
1,171
1,161
E.
that what i first thought as well.
After talking with my fuel supplier though because I only use petroleum diesel he said it can't be algae. He told me algae needs light and my storage tanks are all s/s. His guess was fungus (mushrooms), mould or bacteria.
Regardless never ever treated before.
Given our recent coffee shop arguments, now if I know my fuel is going to sit a month or 3 (for sure if longer) I am hitting it with some stabilizer/treatment.
- Winter is getting a little anti-gel / lubricity improver / and water emulsifier to prevent ice crystals forming.
- Summer lubricity improver / water emulsifier / and cetane increase.
- Spring / fall I am adding nothing as I eat through fuel fast enough to always be fresh like < a couple months old.
My fuel supplier is like a ruddy Ph.D. scientist with all the stuff he tells us for free over a coffee and slice of pie. Downside, I am now getting a bill for additives. A 5 gal. pail is costing us about $300.
Oh well.... better than breakdowns / problems / and equipment being out of service.
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
It's worth it. My BX, like others, is really sensitive to cold fuel; guess I went a bit light on the anti-gel because when it got cold I had minor fuel issues that went away when it got warm out. Since diesel got regulated by the greenies it's not so hot, a bit of lubricant is good for the injectors as is a bit of detergent it's what I'm told.
4,202
My diesel storage tank (for my ranch equipt) may sit for a YEAR or more before it’s re-filled.
I ALWAYS refill it using Biobor JF (anti-bacterial).
The tank sits outside in the sun and weather year-round. JUST LIKE the diesel-fuel suppliers tanks everywhere.
I NEVER have a problem with my diesel fuel.
(I used to refill it with off-road diesel…but when my OFD supplier , who WAS also my home propane supplier for 30+ years) became difficult….I quit PINNACLE …Forever. (Sorry company, never answers the phone, irregular office-hours, Adds stupid, un-approved “hazardous materials fees” and unexplained, unsupportable “surcharge” fees…to invoices.
I last priced OFD (UN-delivered, BTW) with them and they quoted $3.90/gal…when WalMart sells ON ROAD diesel at the pump for $2.95)
I loaded my tank onto the trailer and refilled it at the WalMart retail-pump.
Anyway….. I think there’s a lot of B.S. about diesel-fuel when it comes to “cetane” and “bio” and “algae”…. (there is NO ALGAE …EVER…in diesel fuel…no matter How you Mis-handle it.)
No 2 diesel is good for diesel engines, all you have to do is treat it with a well-known biocide and filter it thru a water-separator filter.
