Yes, it rained this morning.View attachment 180534
This is the area I'm interested in. It may just be a wet spot.
Edit: nevermind, 3074 is what I was interested in, looks ok.
Yeow.Here are close-up shots of the cracks: three photos of the bottom sides and two of the top side, which is a bit tricky to capture.
I think there was a misunderstanding somewhere. I posted in post 120 that a complete new spindle cost over $600, and that didn't include labor or pulley, as I recall. So, if it is repaired correctly, and it appears it is, for $300-400 I think you came out well.You are right. I thought it was supposed to be a new pulley, bolt, and washer, but it turned out to be used parts, including four bolts, yet they charged me as if they were new. I believe they billed $10 for the bolt and $5 for the washer, similar to before, with the total coming to $36x.xx. I removed the bill from the bag that had the old shaft and belt, and if I can’t find it, I’ll have to ask them to email it to me. Should I dispute the charges or also file a complaint with the BBB and Attorney General? This might damage my relationship with them, but they should be honest when using old parts while charging new part prices. The only new thing is "One Blade"
What else is there besides what I discovered above?
If it was me and I saw those cracks on my deck, I would get them welded by a professional welder before putting the deck back on. I think if you leave them as is, they will cause more trouble in the future.Here are close-up shots of the cracks: three photos of the bottom sides and two of the top side, which is a bit tricky to capture.
