Lx2620 buyers be aware
LX2620guy
Lx2620
May 6, 2026
25
17
PA
Do the mower or tractor manuals mention pinning the deck up?
Yes, but the mower manual covers everything from the b2650 up to the lx2620, and it has no specific information about the 2620, there is a bracket that goes on the older tractors that doesn't fit on the newer ones
10,880
The rck60-30bb and the rck60-30bc both have the same deck.
Oliver
L2501, JD 3520
Feb 2, 2011
542
133
Preston County, WV
They took the effort to manufacture both the deck and tractor with tabs to be able to pin up and have been for years. Kubota should make it right IMO regardless what "the rep" said.
LX2620guy
Lx2620
May 6, 2026
25
17
PA
They'll probably do it for the lx2630 and advertise it as a new feature 🤣
3,154
1,275
Is the front linkage and rear lift linkage adjusted correctly? If not then the front or back of the deck may be lifting too high causing it to hit before the holes line up. Try playing around with that and see if you can make it work.
LX2620guy
Lx2620
May 6, 2026
25
17
PA
With the 3 point selector up, the deck touches the frame both in te front and the back and its still like a half inch off, i do wonder if the linkage is adjusted correctly though for other reasons
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,522
548
Do you not have the cutting height dial? I don't need to pin the deck up on my B. Just turn the dial to top position and then I can use 3 point and deck stays up.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
683
797
NE FL
My suggestion is to go through the installation and adjustments outlined in the manual. I bought my LX3310 with 200 hours on it and found pieces left off laying in among the belts and the setup was completely off. No wonder the first owner traded it in on a deere. After setting it up step by step by the manual it mows beautifully.
That said the tractor is fairly useless for tractor work with the mower on. I've tried doing different tasks with mine pinned up and the deck is always scooping up dirt, bottoming out, or in the way somehow. Might as well get used to removing it if it's your only tractor.
SDT
Apr 15, 2018
3,671
1,401
I just got my 60" deck, it works great but be aware that you cannot pin the deck up, the holes are about a half inch off and according to the service rep that is the way it is, they want you to remove the deck for 3 point work.
Had a similar issue when I installed 60" MMM on my B3350, since sold.
Dealer had sent incorrect front mounting brackets with MMM.
Sounds like you need a different "service rep."
bird dogger
Vendor Member
Feb 24, 2019
1,789
1,766
North Dakota
After you've determined original setup was/is correct and don't want to take the time for the dealer to correct it: a "quick" option is to use a sharp point permanent marker to mark the misalignment hole on the metal tab. Then take a die grinder and bit to enlarge the hole to the marked openings on each side for the mower hanger tabs.
you could also have the dealer make the choice to cut which tabs off and re-weld new properly drilled and fitting tabs on either the mower deck or the tractor's mount.
Most times, things like this are quicker done by yourself even though it's apparently a screw up by Kubota. Guessing some worker grabbed the wrong tabs out of a bin and welded them on without checking fitment.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,932
2,332
Western MT
I agree. Sure, it shouldn't be wrong, but if I can fix it, I'm not waiting on the dealer to fix it. At some point, even the principle isn't worth the time to have the item out of service and wait.
SDT
Apr 15, 2018
3,671
1,401
No. OP's deck is not a suspended deck.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,522
548
Sorry, didn't realize the decks were set up differently between these two models. I knew there is suspended and non suspended but I always thought they all had height of cut dials.
PaulL
B2601, MX5200.
Jul 17, 2017
2,788
1,784
NZ
I believe the LX decks ride on wheels (rather than them being anti-scalp wheels). That means the height is adjusted by adjusting the height of the wheels - the tractor can't have a height dial because the tractor isn't holding the deck up.
Pros and cons. I think on a wider deck riding on the wheels lets it terrain follow better, whereas on a narrower deck that's less needed. But I think adjusting the height of an LX deck is quite a bit more fiddly - you have to adjust all 4 wheels.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
195
199
Before I started cutting and drilling on my deck, I would go find another LX like that one and look at it and see if they are really all like that, or if yours is assembled wrong.
It makes no sense to put on a plate on the deck to be able to pin it in the up position, but the holes won't line up.
I think the deck is either built incorrectly or installed on the tractor wrong.
LX2620guy
Lx2620
May 6, 2026
25
17
PA
Im really curious if the updated deck is slightly different
John D 2
Jun 6, 2023
195
199
I saw a YouTube video where a dealer talking specifically about the LX MMM said owners may need to use a floor jack to raise the deck high enough so that the holes will line up for the pin.
But he did say that the LX decks were made to be pinned in the upper position so the 3 point could be used while the deck is on.
LX2620guy
Lx2620
May 6, 2026
25
17
PA
My deck is touching the frame and the hole is still a half inch off
