Lx2620 buyers be aware
SDT
Apr 15, 2018
3,714
1,436
My deck is touching the frame and the hole is still a half inch off
Again, suspect incorrect front brackets and/or improper installation adjustments.
Most dealers will not take the time to properly adjust things upon installation.
LX2620guy
Lx2620
May 6, 2026
27
17
PA
I went through the entire adjustment procedure maybe a week ago, with it adjusted correctly its actually further off
LX2620guy
Lx2620
May 6, 2026
27
17
PA
Why not just fix it with a drill?
I probably can, i just haven't gone that route yet, I'm not particularly upset about it not working, because yeah it does hang down quite low, i was mostly making this as an informative post for anyone who was considering buying an lx2620 and wanted to use the mmm and the 3 point
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,001
2,372
Western MT
I don't have a mmm, but from what others have said here, many people take them off when they aren't being used to improve ground clearance.
In that respect, how much they hang down when not being used wouldn't matter since they wouldn't be on.
PaulL
B2601, MX5200.
Jul 17, 2017
2,812
1,803
NZ
On my B2610 I use the height adjustment to hold it up (not an option on an LX). I often do things with it still on, including using the 3ph. If the things I'm doing don't require ground clearance, then it's easier to just leave the mower deck on. I can't go into/out of my shed with the mower down (it bangs on the edge), if I have something on the 3ph that means it's not all the way up, I need a way to hold the mower deck up. I'm sure there are other people with the same need.
It has an ability to pin the deck up for a reason. It should work.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
723
841
NE FL
I pinned my deck up once but I don't remember if I just raised it or had to pry it up. I do know the holes lined up and the pins went in.
Old Machinist
May 27, 2024
723
841
NE FL
Old Machinist
May 27, 2024
723
841
NE FL
Looks like the OP went on his way. I hope he figured this out before he started griding or cutting.
