Attachment Hydraulic Hose Pressure Relief
nbryan
Jan 3, 2019
1,339
866
Hadashville, Manitoba, Canada
nbryan - what a great idea - retractible cuffs for bad weather and dirt!!
That woven sleeve is f...ing expensive. $5-10/ft depending on size, how the hell can they charge that? Is it some weird material or something? I just about fell over when the stealership told me the bill for a 3ft piece, whoah.
Any ideas out there for a cheaper but equally effective sleeve material?
Shawn T. W
Dec 9, 2024
380
670
SW Missouri Ozarks
Yes, it comes flat with Velcro closure ...
Not sure if @Kennyd4110 ships to Canada ... But these are USA dollars too ... Not sure of the exchange rate.
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
100
107
Bloomington, IN
Using it the 2nd time, there was enough pressure that I broke the pvc valve handle trying to open it. Gave it a re-think and decided that the valve was unnecessary - whole purpose of this is to eliminate pressure buildup. Also moved the pieces around so it's easier to connect to sleeved hoses. Replaced the valve with a piece of pipe nipple. Whatever collects in the bottle gets brushed onto the top of wood fence posts.
