Old_Paint
Dec 5, 2020
1,865
1,939
AL
Been thinking about a flail mower long enough so took a ride up to a dealership near I65 in Priceville, AL that I have passed at least a couple thousand times over the course of my career. I had no clue how to get to it, but it turned out to be not so bad. They sell mostly Mahindra tractors but also sell almost anything else for outdoor fun including CanAm On and Off Road machines and boats of various brands and sizes. Odd to see boats at a tractor dealer, but they’re called Fredericks Outdoors. I reckon that opens up the product line a little.
They had FIVE Titan Implements (now Ironcraft) FL-135 (52” with 48” active cut) that had been in their inventory for a bit longer than 30 months, 2022 models. Paint faded a bit, TI logo on them, and basically being ignored by everyone. I asked the price and the first number came back at the full sales price for a new one straight from Ironcraft. Ummm, nope, guess Im going home. But wait! $2500 (current model list price) out the door was the next offer. “Well, the paint is pretty faded and they don’t seem to be selling real fast. They’re 2022 models.” How ‘bout $2250 out the door? That put it in line with the list price of a new shiny IronCraft FL-135 before taxes. The cheaper stuff was gonna cost at least that and comes with one blade type. The FL-135 comes with both hammers and Y blades. “Load it up!” The price was a little higher than I wanted, but I have been looking and shopping for a while. The biggest problem was finding one in stock that I could actually put my hands on. Two dealers told me “they’re just not at popular anymore “. I didn’t realize mowing in tight places was a fad.
Got home with it and went through all the setup checks and adjustments. I used the shaft for my chipper for testing. I’ll have to cut the one for the mower about an inch longer to make me feel better about the length.
The end result is that it does EXACTLY what I needed for where I’m using it. I’m glad I didn’t get a bigger one for now. Bigger would be better in open field cutting but my lot is covered trees. It’s small enough to get between trees with it and sticks out to the right just enough to get close to obstacles without getting hung up. The terrain is so uneven that I have to use 4-wheel drive and low range to creep around back there and I didn’t see a single piece come out from under the hood. It chopped up some pretty big pine knots and deadfall and went through tall weeds like a hot knife through butter. The only place it made the LX complain was a low flat spot that stays covered by water for at least half the year and has thick wire grass on soft muddy soil. It pulled most of that up rather than cut it, but still, mission accomplished. That stuff is tough and the wet dirt was helping choke the mower, but it didn’t slip the belts or stall the tractor. I did have to lift it a couple times to clear the buildup. I accidentally caught a little 2” cedar with the grapple while I was maneuvering. It’s mulch now. It’s not going to help with the ditche banks but I had fun with double the cutting swath and not getting hit in the shins with pine cones and rocks behind the Swisher. I also enjoyed not being bruised from the waist to my armpits by the handlebars on the Swisher nor having sore knees and shoulders from it constantly throwing me around like a rag doll. I cut about a third of the area a lot quicker than I expected and was a little disappointed that it was so easy to do. It used to take me about 6 hours with the Swisher and roughly 8 gallons of water for me a 2 gallons of gasoline for the Swisher. I’m thinking maybe 3 hours with the LX now, and a lot less brutality. I was mostly learning how to best use and maneuver it among the trees and uneven terrain and also checking the cut at maximum height. I think I need to lower it a little for a little cleaner cut, but it was low enough to pick up a couple fist sized rocks (which it destroyed). Gonna take a bit to dial it in. I may get a separate top link so I don’t have to reset it every time I use it.
Now I’m better equipped to manage the back part of the lot and keep it that way without taking a beating. I’ll still have to work the ditch banks with my trimmer, but a hedge trimmer attachment is the cat’s pajamas for that. I don’t have to constantly stop and pick up sticks that are very unfriendly under the Swisher. I will probably still need the Swisher in a few places where the terrain is too dangerous for the tractor but only when absolutely necessary.
The FL-135 gear box is a bit noisy but I think that will get better when some of the new rubs off. It’s noisier unloaded than when cutting, so I’ll assume it’s just gear lash. I’m going to put a couple hours on it and change the oil in it just to make sure it doesn’t have a bunch of water in it. It’s been sitting on their lot outside for two and a half years. The small sample I took looked okay and smelled okay, but I want fresh stuff in the box and drive line. I may have to remove the gear box to thoroughly drain it. That’s perhaps my biggest gripe about it , but the grease zerks are easy to get to without removing any covers. Overall, I give it a B+ for what I use it for. My use is probably more of a factor than any shortcomings of the machine.
Reactions: 9 users
6,623
By your description you got the hammers on it? I have a 5' flail I use around some pine trees. It has the "Y" knives. I mow out in the open around the trees and then back into them. The mower gets under the lower limbs and when I pull out it looks like it's been mowed with a push mower.
I got this Ford from a guy who bought it at an auction and thought he bought a tiller. :(
S-G-R
Grand L5460
Jun 17, 2020
1,353
3,147
PEI Canada
Sounds like you got a great fit for your property. I think changing the gear box oil is probably a good idea and then you know what you've got.
I was at the dealership signing paperwork on the L5460 and they had a Del Morino flail on a LX2620. It had tilt and side shift. A cool unit but I don't have a need for one at this point.
Old_Paint
Dec 5, 2020
1,865
1,939
AL
Yup, two tractors, two QH's !
While my Kubota Grand L 5030 is CAT 1/2, I'm setting it up as CAT 1, so I can utilize some of my attachments I have for my Massey Ferguson SCUT.
Just order a hydraulic top link for the Kubota too!
Those are radials I believe, or at least the ones I've seen were, they have great reviews, probably better then R14's for the size of tractor you have them for.
Ah, ok. I somehow thought you were trading up, not buying a new one. Tell me something though. Do you have someone to drive that second tractor or have you figured out how to run two at a time? The missus might let me have another one if you share that secret. The first one is almost paid for (last payment is due November). I reckon I need a new one now, right? She’ll probably disagree though.
Old_Paint
Dec 5, 2020
1,865
1,939
AL
View attachment 159687 View attachment 159688 View attachment 159689 View attachment 159687 View attachment 159690
Yep, hammers were already on it, and the Y blades were in a bucket along the required bushings and bolts. Finished cutting what I could today. Took me less than 1/3 the time (and probably fuel) and didn’t run up my water bill keeping me hydrated. The only thing I regret about having a flail is not having it sooner. Now to upgrade the box blade to something wider than the back tires……
Shawn T. W
Dec 9, 2024
193
302
SW Missouri Ozarks
Nope, just me ... The cats haven't figured out how to turn the key, yet! But he is a pretty good navigator!
Two tractor, two different sizes, different jobs in general ...
The MF SCUT TLB is the Swiss Army Knife Tractor that really does everything I need done, and I have quite a few attachments and accessories for it ...
The Kubota was bought primarily for the much larger tires, to provide more comfort in mowing the 14 acres of fields ... Bigger tires 52" compared to 26" are not as rough riding, and can actually go faster over the fields with more comfort ... It also came with more than twice the motor ... 52 HP - 44 PTO HP, vs 25 HP - 19 PTO HP ... So I can run a wider mower ... The Kubota also has a cab with A/C so that makes mowing a more comfortable time, all while keeping the bugs and flying grass bits off from me ...
Reactions: 6 users
Old_Paint
Dec 5, 2020
1,865
1,939
AL
I waa considering tilt and side shift, but that was gonna add another $2000 for rear remotes bringing the total up to around $6K. Then I thought about the work to remove all the trees along the edges of drainage ditches (more cost) and decided to get something I can back between the trees with until I decide which ones to keep. I have the LX 2610SU (special utility) version w/o mid mount capability, which was originally going to be a backhoe machine.
Cutting around trees is cumbersome and requires some patience but I choose to keep them because they keep some cooler air close to the ground and don’t let the sun fry my chickens. I like fried chicken, just not mine. Ennyhoo, I did in about 3 hours what used to be an all day job with my walk(drag) behind brush mower. I’m quite pleased with it. I was a little worried about hitting sticks with it at first, but it didn’t take long to ignore the noise other than a screeching belt. I’m of the opinion this mower might be tougher than I originally thought. The only thing Ive had bother it was some wire grass and I wrapped a wild scuppernong vine in it today. Not to worry, it beat the vine up after s little bit of shaking and complaining. I guess I’m taking it off tomorrow and hoping stuff grows back quickly so I can have all that fun again. We’re in the middle of what call “Dog Days” right now. Nothing growing very fast, birds won’t sing (unless I tease mine with mealworms) just cicadas and stifling heat and humidity. If I complain about the heat, there’s probably all kinds of heat advisories and warnings on TWC and my wife has become an endomorph leaving all the outside chores to me. Except the chickens. They were her idea and she did all the chicken math that made the larger coop necessary, the birds are all pretty docile and like attention, so she’s pretty hands-on with the girls.
nerwin
Nov 13, 2024
527
1,272
Vermont
youtube.com
Weighed the ballest box today with my new crane scale. Don't mind my rigging, only lifting it an inch, it was fine though. Didn't move at all.
640 pounds, not bad! Was close.
One interesting thing to note. When lifting this with the loader, I felt nothing. It's like it wasn't even there. But when lifting it with the 3 point, I can feel the weight. It's super interesting! I guess it's just the way the load is distributed.
JonM
Kubota Grand L6060
Nov 29, 2024
wisconsin
Jon - true.
For a while we had few Belgians and Percherons in the barn.
I was young, and they’d look for me each day when I came down to check on them and do chores.
Spent a lot of time with them. They’d complain when I left.
Doesn’t get any sweeter.
we have 4 friesian with one on the way in spring. 1 quarter horse 1 arabian 29yrs old and 1 percheron quarter horse mix.
S-G-R
Grand L5460
Jun 17, 2020
1,353
3,147
PEI Canada
Cleaned out the cab of the LX3310 and dug out the blower and subframe for it's trip to the dealer. The L5460 is getting delivered tomorrow morning and I've got a few things lined up to do to it and with it after it's dropped off.
BBFarmer
Jul 12, 2024
563
1,130
Terry, MS
Can see the obvious difference in cab height and width!
It is quite the difference.
Sounds funny, but one of/ if not the biggest deciding factor for me getting a cabbed grand L over a cabbed standard L was there was absolutely no way I was fitting the wife in there with me. She wanted to be able to ride at times. All I wanted was A/C.
I made a stool that fits perfectly to my left up against the cab corner. Clears the pedals, and plenty of room for my left leg and both of hers. Happy wife, happy life..... sometimes LOL
S-G-R
Grand L5460
Jun 17, 2020
1,353
3,147
PEI Canada
Can you post a picture of the stool? Wife probably won't want to be in there with me but the grandkids will.
nerwin
Nov 13, 2024
527
1,272
Vermont
youtube.com
Soooo I just noticed the Land Pride WB10 weight box I have is messed up. Where you slide the lift arms onto the pins is bent on both sides outwords making it INCREDIBLY difficult to get on and off. I looked up pictures and they are straight. I'm wondering why they're bent? I'm thinking about bending them back and perhaps welding some gussets on it.
What all the other pictures look like online:
Mine...
  • Sad
MOOTS
MX6000
Jun 27, 2019
2,164
2,687
Canton, Georgia
Mine...
Remove pins and massage with BFH. Reinstall pins.
Reactions: 7 users
