3 point lift?
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
I wasn't try to diagnose the problems.
Just showing the OP where the hyd. screen is on his tractor and how to tell when it's had enough fluid dumped in it.
I suspect that filling that cavity up to the fill hole would be an excessive waste of hyd fluid maybe even another 5 gallon pail. Which would be wasting 30 dollars.
Just trying to inform and save a brother some money not diagnose.
Hi royboy,
Many apologies to you if my post came across as demeaning. The worst methods of communication is this. Texting, emailing and it's all in the forum's. There is no way to determine the mind set of the person's intent without voice deflection or facial expressions.
Basically on my previous post I was inquiring about how this particular tractor works as compared to what I have experience on. Airplanes. I really didn't know if there was or was not a vent on this tractor or how it actually functioned.
The reason I made the comment about throwing myself to the blood thirsty hounds is also from my experience. Making any type of questioning statements on a forum can be very humbling, at the least, by the the people responding who do know how a system works.
So I was preparing myself for the forth coming blood bath of explanations on how I was wrong. Sort of like me sticking my ass out there and learning how a three point hitch actually works on MY tractor (very embarrassing) and that not all Kubota engines have water circulation pumps. Both very humbling experiences :eek:
Damn, I'm not even making sense with this :rolleyes:
You did a great job on researching for the OP and I didn't.
Take care roy and hope to see you on the forums!
Scott
Lil175
12
Glenwood,Ar
The guy I got it from had pulled the geared shaft that the 3 pt arms hook to out of the assembly. This allowed the hydraulic piston and the the knuckle to fall down into the rearend case. I drained out all the oil cleaned and replaced the filter, new oil, then put the lift assembly together and reinstalled it on the tractor,made some adjustments on the lift arms and wallah working 3 pt. lift and I'm quit happy!!
traildust
Jan 27, 2010
1,490
Phelan, California
CONGRATULATIONS
The first round is on me :cool:
Scott
dusty-t
974
Mountforest Ontario
I think you said something about it in the thread and I had the thought NA nobody would do something like that. Glad you found the fix. When I found that there would be more than a few choice words.:cool: Dusty
Lil175
12
Glenwood,Ar
Lol! I half expected something like that, this guy would have had a hard time changing a light bulb I'm afraid.I'm glad it was an easy fix and it didn't cost an arm and a leg.
