Sorry my initial spouting off / thinking was too old school... Yes you have a wet clutch that's inside the transmission.
The control valve for it is external and there is one adjustment on it, If you can get to the valve In Picture 4 look at #'s 210, 200, 190, 180, 170 and see if they are loose. if they are it's probably come out of adjustment.
Also when was the last time you did a fluid and filter change?, being a wet clutch assembly it's susceptible to pressure variation due to restricted fluid movement.
#1 Wet PTO clutch pack
#2 Wet PTO clutch pack
#3 control valve and actuator
#4 break down of control valve
![M6800HDC 4.JPG M6800HDC 4.JPG](https://www.orangetractortalks.com/forums/data/attachments/8/8905-332604a9538af5f7f180f0f8a3a2a721.jpg)
